Go to Post the golden rule of robotics for the 21st century: Do unto robots as you would have them do unto you - KenWittlief [more]
Unread 10-01-2008, 02:14
Gabe15's Avatar
Gabe15 Gabe15 is offline
FRC #1584
Gabe15 is an unknown quantity at this point
NEED: carbon fiber/kevlar/composite I-beam
I found a great website last year that sold carbon fiber and kevlar I-beams, angle beams, all kinds of shapes you would normally probably buy in aluminum extrusion (also sheets, panels, grates...). I cannot find that site nor any others like it. So does anyone know a supplier of this kind of material?
I was hoping also there might have been a material resource section of this site, but canʻt find anything like that. Would be nice to start something like that perhaps, unless Iʻm missing something.ʻ
Thanks!
Unread 10-01-2008, 08:32
richalex2010 richalex2010 is offline
AKA: Jake Alexander
FRC #0177 (Bobcat Robotics)
richalex2010 will become famous soon enough
Re: NEED: carbon fiber/kevlar/composite I-beam
Not much help with the I-beams, but this is a great site for supplies to make your own parts (not too hard): http://uscomposites.com/
They've also got resins, brushes, gloves, mold material (rubber, though you can use anything as a mold, including wood and metal), mold release (carnauba wax), gelcoat (big thing... adds a hard, smooth finish to the material), etc.
http://www.acp-composites.com/ is another great place to get stuff. They have pre-made parts, though I'm not sure if they're in the sizes you need.
It seems that, at the moment, it may be easier to use fibreglass and/or Kevlar, because there is an industry-wide carbon fiber shortage. There is (as I recall from a year or so ago) only one factory in the world making it, and the US government is taking up quite a lot of it for new combat aircraft (F-22, F-35). There are/were plans to build a second plant, or convert another to carbon fiber manufacturing, but I haven't heard about it since I stopped doing model rocketry as much.
As far as using fiberglass goes, you want to use the matte material (unwoven) for most everything, and woven stuff for reinforcement. Also, use true epoxy resin (Aeropoxy, West System), not polyester. And try to vacuum bag if you can, as it removes air bubbles. If you can put it on a sheet of balsa (a couple of layers per side on a sheet of 1/16" balsa, for example - you may need/want more fiberglass or wood), you can get incredibly strong sheets, far stronger than wood, but just a bit heavier than a balsa sheet.
A note about using pure composite: Resin is heavy. It makes up most of the weight of a material, because there needs to be a lot of it. Make sure you have the weight before you use composite parts.
-Jake Alexander
-Jake Alexander
Unread 10-01-2008, 08:44
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
McMaster has FG I-beams as well as some other shapes too.
Also, talk to squirrel from 1726. They have used FG I-beams on some of their robots I believe.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Carbon Fiber Jeff K. Technical Discussion 29 19-10-2006 23:05
Carbon Fiber Bicycle Fabrication Peter Matteson Technical Discussion 5 07-12-2004 18:31
Carbon fiber edomus General Forum 4 19-02-2004 19:02
Carbon Fiber kbmeister Kit & Additional Hardware 6 07-01-2003 12:24
Carbon fiber? Munchausen Technical Discussion 1 25-01-2002 21:20
