Go to Post Cameras, colors, and tetras, oh my! - galewind [more]
Unread 10-01-2008, 08:51
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Re: A Better Gear Tooth sensor
Originally Posted by Alan Anderson View Post
Easier to mount than what? The KOP gearbox has a perfect spot for placing the KOP gear tooth sensor, complete with mounting holes.
The FIRST GTS boards are designed to mount in the gearboxes. The features are provided (although the fasteners are not!). That is where we will use them.
But what about everywhere else on the robot? Placing the fragile board anywhere on the robot other than the inside the protective confines of the gearbox would be inviting disaster. Building protection would be required, but we only have so much time and resources.
The Honeywell sensors are cheap, very reliable, have a very clean signal, easy to use and are nearly bullet-proof.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
