Motor for a forklift
We are going with a forklift design and with the absence of the minibike motor we are looking for an alternate to raise/lower our forklift. Would using both fp motors create enough torque to lift a 6lb structure plus the 10lb ball at a reasonable speed? Or would the globe motors be a better alternative?
Re: Motor for a forklift
we're probably using the a FP also, and for the same idea... probably...
FP motors with the gearboxes are more powerful than globe motors. so yes, i would advise using FP's.
Teams 968 and 254 used 2 FPs and a rotating drum last year for their lift bots.
Two FPs, stock gearboxes, is a classic BeachBot trick. The 2007 (and 2005, if we hadn't used a PVC arm) robot arm could lift our driver, and he's at least robot weight (I think...)--at least 2007 could before we took off one motor to make ramp weight. Our 2004 robot had 2 FPs on one drum and winched itself up on a bar--that's 120 pounds + battery, all on two FPs through the gearboxes and the frame through screws in the mounts. Two FPs might even be overkill, but you might want that.
#7
Remember that the van door motor is back in the kit. (I haven't checked to see if it's the same as previous years as far as performance but I would assume it's similar). In 2k1 we used a van door motor tied to a drum. The Van door motor can be direct driven as is because it has a worm gear box built into the casing.
FYI: If you didn't know, 2k1 had similar size/weight balls. On second thought, it would probably be faster using the FPs, but just throwing more ideas out there. Last edited by Matt C : 10-01-2008 at 09:21. |
#8
We used the keyang motors last year to work our arm. Those things are super torquey and don't backdrive.
| Forklift | FRC1710 | Technical Discussion | 14 | 08-01-2008 12:51 |
| pic: Forklift Surprise | triggerhappy336 | Extra Discussion | 1 | 18-04-2007 12:04 |
| What kind of material will you be using for your arm/forklift? | Atman | Technical Discussion | 35 | 31-01-2005 15:28 |
| White Paper Discuss: Approx. Motor Spec for Taigene Motor | Joe Johnson | Motors | 2 | 22-01-2005 16:36 |
| Image Discuss: Nice Forklift! | CD47-Bot | Robot Showcase | 1 | 15-02-2003 18:07 |
