Go to Post FIRST is an opportunity for me to tackle problems that have long been solved. - Madison [more]
Unread 10-01-2008, 00:05
calvin1631 calvin1631 is offline
FRC #1631
calvin1631 is on a distinguished road
Motor for a forklift
We are going with a forklift design and with the absence of the minibike motor we are looking for an alternate to raise/lower our forklift. Would using both fp motors create enough torque to lift a 6lb structure plus the 10lb ball at a reasonable speed? Or would the globe motors be a better alternative?
Unread 10-01-2008, 00:12
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: Motor for a forklift
Yes. As long as you use a gear box. We actually just used our 2007 lift to lift the ball and it is driven by just 1 FP motor using an AM Planetary and a 56mm BaneBots Planetary. It was fast, but it was moving at a snails speed either.
Team 1538 / The Holy Cows, 2005-2016
Unread 10-01-2008, 00:45
pakratt1991's Avatar
pakratt1991 pakratt1991 is offline
AKA: Tim L.
FRC #0997 (Spartan Robotics)
pakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nicepakratt1991 is just really nice
Send a message via AIM to pakratt1991 Send a message via MSN to pakratt1991 Send a message via Yahoo to pakratt1991
we're probably using the a FP also, and for the same idea... probably...
2010 Oregon Autodesk Regional Winner (997, 2130, 1515) (Event Volunteer)
2008 UC Davis Semi-Finalists
2007 Championship Semi-Finalist (494, 254, 997)
2007 Davis Sacramento regional Champs (100, 997, 1458)
2007 PNW regional, Champs (997, 272, 1087)
Unread 10-01-2008, 00:53
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
FP motors with the gearboxes are more powerful than globe motors. so yes, i would advise using FP's.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-01-2008, 01:00
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Teams 968 and 254 used 2 FPs and a rotating drum last year for their lift bots.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 10-01-2008, 01:04
Two FPs, stock gearboxes, is a classic BeachBot trick. The 2007 (and 2005, if we hadn't used a PVC arm) robot arm could lift our driver, and he's at least robot weight (I think...)--at least 2007 could before we took off one motor to make ramp weight. Our 2004 robot had 2 FPs on one drum and winched itself up on a bar--that's 120 pounds + battery, all on two FPs through the gearboxes and the frame through screws in the mounts. Two FPs might even be overkill, but you might want that.
Unread 10-01-2008, 09:16
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Remember that the van door motor is back in the kit. (I haven't checked to see if it's the same as previous years as far as performance but I would assume it's similar). In 2k1 we used a van door motor tied to a drum. The Van door motor can be direct driven as is because it has a worm gear box built into the casing.
FYI: If you didn't know, 2k1 had similar size/weight balls.
On second thought, it would probably be faster using the FPs, but just throwing more ideas out there.
Unread 10-01-2008, 11:30
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
We used the keyang motors last year to work our arm. Those things are super torquey and don't backdrive.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Forklift FRC1710 Technical Discussion 14 08-01-2008 12:51
pic: Forklift Surprise triggerhappy336 Extra Discussion 1 18-04-2007 12:04
What kind of material will you be using for your arm/forklift? Atman Technical Discussion 35 31-01-2005 15:28
White Paper Discuss: Approx. Motor Spec for Taigene Motor Joe Johnson Motors 2 22-01-2005 16:36
Image Discuss: Nice Forklift! CD47-Bot Robot Showcase 1 15-02-2003 18:07
