Go to Post edit: laptop. yeah as a programmer to not put this in I should be taken out the back and "decompiled". - Stuart [more]
Unread 10-01-2008, 12:04
bobdahaxor's Avatar
bobdahaxor bobdahaxor is offline
Making the impossibe... possible
AKA: Andrew Lane
FRC #1727 (Dulaney robotics)
bobdahaxor is an unknown quantity at this point
Re: Disengaging a motor on a spring powered hurdler
as I ranted in one article, be careful. Springs are dangerous, and you need to pull them back. Even the 2" bores can only produce a maximum of 189 pounds(foot pounds?) of force/ energy. This is going outwards not inwards which is what you need. so at @ 180 b/c you loose energy to heat, a bullet produces at a minimum 1000J. in reality, do you want the energy of a .22 firing your ball upwards? if you ever have fired a gun, .22 is an oversized BB gun essentially.
hurdler or herder? XXShadowXX Technical Discussion 17 08-01-2008 17:16
RC Powered on 7.2v backup chris31 Electrical 10 17-10-2006 11:02
Gas powered engine horsepower equivalent to electrical motor horsepower? Elgin Clock Motors 30 22-08-2004 20:44
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Powered OI input EricS-Team180 Programming 7 28-09-2003 21:23
