Go to Post the weather always does funny things to people, like when it snows, all these engineers take kids, lock themselves in machine shops & build robots......weird - Lisa Rodriguez [more]
Unread 10-01-2008, 09:32
robotchibi's Avatar
robotchibi robotchibi is offline
FRC #2423 (kwarqs)
robotchibi is an unknown quantity at this point
Talking Which one? (Be helpful if you had pros and cons with your answer)
So we have to ideas for herding and we're having a lot of trouble deciding the first one is: two arms are going to come down (cause in the beginning they stand up right in the front of the robot) and are diagonal facing out on the right side is a little extra piece facing in slightly so that when it goes around the ball it holds it in so it doesn't leave. The ball is still able to role but in a confined area. The other idea is: something that we attach to the bumper's corners like long plastic materials so that when the ball hits it will hit it more on the "equator" the at the bottom where a regular robot will hit the ball.
Thank you to anyone who answers this it will really be helpful
And sorry if you don't get it or it's to long -.-'
bbbbbooooorrrrreeeeeddddd!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
ha just kidding but not really
hyper...ish >.>
Unread 10-01-2008, 12:06
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Re: Which one? (Be helpful if you had pros and cons with your answer)
I don't quite understand if you can only do one or the other, because I cannot visualize your description of the second concept.
But for the first one, this sounds feasible to use for herding. Just a couple of considerations: Make sure that the "arms" are strong enough to take a ball dropping / bouncing on them from the hurdle height. Make sure you plan on a way to ensure that you can release the ball as you cross your finish line or you won't get the points for herding the ball. And make sure you keep the the robot with its arms extended within the 80" imaginary cylinder.
Good luck!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Unread 10-01-2008, 12:09
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I would go with the one near the equator of the ball. You will be less likely to lose it if someone hits the ball.
Also make it robust
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
GaryVoshol's Avatar
Cogito ergo arbitro
You can't attach anything to the bumpers. That would make them non-standard.
(since 2004)
6WD Pros and Cons ChuckDickerson General Forum 59 13-01-2008 02:20
Kitbot pros and cons Jaybee1405 Kit & Additional Hardware 16 06-01-2008 23:57
Pros and Cons of Using Pneumatics Joe_Widen Pneumatics 22 30-06-2006 10:16
Motor Placement Pros and Cons Pattie Motors 17 24-01-2005 15:40
Timing belts pros and cons!!!! archiver 2001 3 24-06-2002 00:33
