Go to Post You need to stay on top of your classes or you will be back as a returning freshman on next year's team. - [more]
Unread 10-01-2008, 11:53
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Disengaging a motor on a spring powered hurdler
We are working on a hurdler design that will use a large spring to hopefully accelerate the trackball enough to clear the overpass. Since safety will obviously be a concern, we will mount the spring in a protective cylinder, have a cable running through the center of the spring, use at least two strong latches to hold it in place when loaded, have a way to release tension in the spring safely without firing the mechanism, and use a two step process to fire the hurdler on the operator panel to help prevent accidental firing. (Comments on the safety of such a device or additional precautions would be greatly appreciated.)
To retract the spring, we will use a winching mechanism. However, the motor used will have to disconnect from the winch so the mechanism can fire. Does anyone have any suggestions on how to accomplish this? One idea was to use a shifting gearbox with a speed missing, but as we have used all of the CIM motors in the drivetrain, there are none available for use in, say, an AndyMark shifter. We do not have the capability to make our own gearbox. Does anyone know a way to connect a different motor to a shifting gearbox, any other suggestions on how to disconnect a motor, or a suggestion for a winch design where this wouldn't be required?
Thanks!
Unread 10-01-2008, 11:57
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: Disengaging a motor on a spring powered hurdler
Don't they make pneumatic cylinders only use air in one direction. Single action acting cylinders I believe... Anyways you could use that to pull the spring back, let out the air and the spring expands.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 10-01-2008, 12:04
bobdahaxor's Avatar
bobdahaxor bobdahaxor is offline
Making the impossibe... possible
AKA: Andrew Lane
FRC #1727 (Dulaney robotics)
bobdahaxor is an unknown quantity at this point
as I ranted in one article, be careful. Springs are dangerous, and you need to pull them back. Even the 2" bores can only produce a maximum of 189 pounds(foot pounds?) of force/ energy. This is going outwards not inwards which is what you need. so at @ 180 b/c you loose energy to heat, a bullet produces at a minimum 1000J. in reality, do you want the energy of a .22 firing your ball upwards? if you ever have fired a gun, .22 is an oversized BB gun essentially.
Unread 10-01-2008, 12:25
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Have you considered cam designs, as a potential replacement for your winch? Basically you have a spiral, starting with a small radius, and increasing over one revolution to a large radius, then snapping back to the small radius. As the motor turns this, the spiral pushes back on your spring. When it passes the drop from the large radius to the small radius, it releases the spring.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 10-01-2008, 12:32
jfrank's Avatar
jfrank jfrank is offline
FRC #2668
jfrank is an unknown quantity at this point
i don't think you are allowed to store energy (like in a spring)
Unread 10-01-2008, 12:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You are allowed to use stored energy under the conditions stated in the rules.
if you are planning on using air to compress the spring....why not eliminate the spring and use the air itself as a spring?
Unread 10-01-2008, 12:58
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
So to answer the actual question posed, 57 had a mechanism like this last year. You'll find that the vast majority of devices out there simply won't release under load. If you're winding back and then using the latches to control the final release then it's not as much a problem and you could use an andymark shifter and an andymark planetary adapt an FP to the tranny. That would work fine as long as you back the motor up so the springs take the load before you try disengaging.
That said, our solution was a little different. We used a worm-worm gear combo to drive the retracting pulley. An FP through a BB tranny drove the worm, and that whole assembly was mounted on a pivot and gravity biased to the worm wanted to pull away from the gear. So to retract, we'd use a cam on a servo to push the worm into the gear and retract. To fire, we'd move the cam the other way and then we'd have to reverse the motor slightly. The worm was arranged such that while retracting, it was actually pushed into the gear thanks to the location of the pivot point. Reversing the motor broke changed thing s enough that the worm broke free of the gear and out went the spring.
Unread 10-01-2008, 13:52
MrForbes's Avatar
AKA: Jim
That sounds interesting Kevin, do you know if there are any pictures of it on the web somewhere? where they might be?
Unread 10-01-2008, 14:55
I don't think there are any. At least, I didn't take any, and it's buried inside the robot, so it's unlikely to be visible in beauty shots. As a caveat, it took build season and most of two regionals to get the working combination of software and hardware. And then an unkind robot picked out the one weak point and broke a delrin flange that attached the pushing plate to the pushing rod. Much of our time during build trying to get it to work was fruitlessly attempting to adapt various pre-made release devices to the system, like a heavy duty fishing reel, etc. That would be how we discovered that many such mechanisms lock under load. I imagine a dog shifting transmission isn't likely to be much better.
The beauty of the worm gear design was that an appropriate worm meant the system wouldn't backdrive, and yet the arrangement of it all meant it would get out of the way when firing time came. Were I to apply it to retracting a heavier spring like you would need for this task, I think I'd look very carefully at a small piston to engage and disengage the worm instead of depending on gravity to release it and an admittedly not entirely sturdy cam on a servo to keep it engaged.
Actually, come to think of it, the biggest single advantage of this system is the it's much more likely to be safe. Using the latches to hold the punch while under load means that if your latches fail, then the motor either has to hold the load itself or slowly release it, and either one takes a lot of amps. You'd have a similar problem if low volts or mechanical problems prevented the punch from fully retracting. With the worm system, the motor can latch or release the punch at any point, so the only dangerous point of failure would be the mechanism that holds the worm on the gear. And if that can only engage the worm and you depend on a spring or gravity for release, then that's pretty good too...
At any rate, as I said above, I don't have a picture available. I'll try to snap one tomorrow or this weekend, but I'll also try to cad up a schematic of the arrangement and how the forces end up making it work.
Unread 10-01-2008, 15:05
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
Why not use a winch to pull it back to a latch and then unwind the witch letting the cable go slack or mabey using a really weak spring that pulled the cable in some other direction just to keep it from floping around. This way you wouldn't need anything more than your winch and the latch on the spring.
Unread 10-01-2008, 15:34
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Or you just buy an automotive winch that free wheels and adapt a kit motor to the planetary it comes with. Just fire a pnuematic to lock the winch in and release the free wheel to retract or release.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 10-01-2008, 15:57
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
OK JUST as an example... (I lived in Europe... I do dangerous things...) NOT FOR ACTUAL USE but for illustration purposes... if you has two identical Metal hole saws...
http://media.incomsupply.com/products/338672.gif
and Meshed them teeth to teeth, on a shaft, they would lock in one direction. One attached to the winding spool (fixed in place) , one attached to the motor such that it can retract away from the ... winding spool hole saw... , You can wind the spring back... Retract the Motored saw... and Yell "SCOTLAND Es FRE'!!!! Or something equally appropriate when looking for deadly outcome with a projectile...
The concept is having two plates that lock and then releasing them, by separation.. re engaging them to start the cycle over...
Um.. In case you missed it... DON'T ACTUALLY USE the Metal Hole Saws!
In fact... forget I said anything!
Steve
Unread 10-01-2008, 17:18
Steve
See, we too were thinking along these lines last year. The problem is that any of these mechanisms that we found would lock under load whether by design or lack thereof. To the former, I'm absolutely certain that the freewheel on an auto winch is designed to lock under load. Or, at the very least, be very difficult to release under load. Imagine the consequences if you could easily bump the freewheel while using the winch to lift/tow/pull something.
Similarly for the locking plates. Going down the spectrum from profiles that don't lock under load to those that do you have:
1. If you trace an imaginary pencil from right to left along the "hole saw" teeth, it would never have to move to the left to follow the teeth. This triangle-wave like profile gets harder and harder to hold together the more torque you apply. Easy to release, but hard to load.
2. Your imaginary pencil goes straight vertical tracing a tooth. This sawtooth profile is probably the best bet. Dog shifters like the Andymark shifter rely on flat surfaces like this. Holding thing together isn't particularly difficult, but to release them, you do have to overcome the static friction of the two surfaces being pressed together.
3. If your imaginary pencil has to move to the left at some point while you're trying to trace to the right, then you're really in trouble. This profile would lock together very well under any kind of pressure, but would be very difficult to pull apart, as to do so, you'd have to turn either the input or output side by pulling apart hard enough to backdrive it.
So, I think dog shifters and veeery mild profiles in category 3 would work, but they get harder and harder to release as you put more and more pressure on them.
Unread 10-01-2008, 17:25
This can be fixed by "re-working" the mechanism. We made a compact shoulder out of a modified winch in 2005 and never had a problem once we worked it over. It cost us $70 and we had to machine 2 parts (motor mount and input shaft) to get it to work. It's a cheap solution that you can make work with minimal effort if look around.
Thank-you 294 & 67
Unread 10-01-2008, 23:25
chapmatr's Avatar
chapmatr chapmatr is offline
Zippidy bling-zap whippy-wog snizin
AKA: Travis (Lead Programmer)
FRC #1676 (Pascack Pioneers)
Team Role: Driver
chapmatr is an unknown quantity at this point
Send a message via AIM to chapmatr
We were thinking of using a gear with teeth missing to pull it back, although that would require a non-winchy device.
Did you know that 87% of all online statiscs are made up?
hurdler or herder? XXShadowXX Technical Discussion 17 08-01-2008 17:16
RC Powered on 7.2v backup chris31 Electrical 10 17-10-2006 11:02
Gas powered engine horsepower equivalent to electrical motor horsepower? Elgin Clock Motors 30 22-08-2004 20:44
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Powered OI input EricS-Team180 Programming 7 28-09-2003 21:23
