Go to Post So yeah I love the minibot because it was a great vehicle to promote our team, make new friends, and possibly make sure a team makes it past their 1st or 2nd year. - Mr V [more]
Unread 10-01-2008, 13:48
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Trackball inflation
As a former gauge engineer.... why don't they come up with a simple set of GO/NO GO gauges? The GO would tell you if the trackball is too big in diameter and the NO GO would tell you if the trackball is too small in diameter. By passing through the GO, you would know the trackball was not too big and by not passing through the NO GO, you would know that the trackball was not too small. The gauges could be as simple as two pieces of lexan, if you wanted a 40" diameter trackball, one would have a 41" hole (GO, not larger than 41") and one would have a 39" hole (NO GO, not smaller than 39").
If you are more concerned with bounce/air pressure, a simple pressure gauge would work.
Enevitable- Trackball popped pheadxdll Kit & Additional Hardware 30 03-02-2008 08:08
Trackball scoring ZP8892 Rules/Strategy 6 06-01-2008 08:52
change in trackball size Dan Zollman Rules/Strategy 1 06-01-2008 00:22
Intertube inflation? G-Ball Rules/Strategy 6 09-02-2007 13:48
game ball inflation archiver 2000 5 23-06-2002 22:28
