Go to Post I'm wondering just what you think the people who DID set this system up actually do for a living instead? Sheep farmers? - DonRotolo [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 20-01-2007, 12:07
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: Programming - Getting Started
Something else that's amazingly helpful is WPlLib. WPIlib simplifies programming a great deal by storing a vast majority of the code in a library file that is automatically called when ever you need it. No default code is needed. Further description, documentation, and downloads can be found here. A thread on the subject is located here.
  #62   Spotlight this post!
Unread 21-01-2007, 09:51
Overdue for updated links and accounting for 2007 changes...
2007 Programming Quick Start
1. Beginners need the following to program the FIRST robot:
v FRC (Full-size Robot Controller) RC Default Code
v Microchip MPLAB & C compiler (only from the Kit-of-Parts (KOP) CD) or Intelitek Easy C also in the KOP.
v IFI_Loader v1.1.0 (from the KOP CD)
v A standard serial cable
v A Windows PC with a serial port or USB-to-serial converter
2. Where to get everything:
-Basic default code, updates, documentation, and support information is available on the Innovation FIRST (IFI) website, in particular at:
v 2007 default code comes ready for basic driving and with a variety of sample I/O usages.
v Robot Controller
v Operator Interface
v CMUCam2
-The Camera default code for use with the CMUCam2 camera comes in two versions, one for the MPLAB native C programming environment and the other for the EasyC development environment.
The MPLAB version is available at the developer Kevin Watson’s website. While there you’ll also find code examples for using other beneficial sensors. This default code may have the normal driving mode disabled.
-MPLAB is the FIRST supplied Windows based development environment (edit, compile, debug) that runs on your desktop computer and comes in the Kit-of-Parts wrapped inside the small clipboard. Manuals for using MPLAB come on the CD and are also found hosted on-line at Kevin Watson’s website.
IFI_Loader v1.1.0 (also on the KOP CD) is used to download the compiled code into the RC via a serial cable from your desktop or laptop computer.
-EasyC from Intellitek can be used instead of MPLAB or as a rapid prototyping tool. It came in the KOP in the bag with the robotics magazines. The Main Contact of each team received an email from FIRST a software key to activate one installation of the software.
-- The EasyC version of the Camera default code for use with the CMUCam2 camera is available at Intelitek's website.
3. National Instruments Labview came in the kit-of-parts and has some optional special applications for the camera and OI dashboard among others have been provided in this Chiefdelphi thread and discussions can be followed in the Chiefdelphi EasyC Pro forum.
4. WPI has developed a potentially useful approach to programming your robot. Details are at WPILIBand discussions can be followed in the Chiefdelphi WPILIB forum.
5. Check the IFI website periodically for updates to the software that corrects issues and fixes problems. For instance, new Master Controller “patches” if any, will be made available there. Directions will be included with any download.
6. The programming language used is “C”, EasyC, or PIC assembly. Tutorials in C can be found on the web, in your local bookstore or on the FIRST website, e.g.,
-- C Programming Resource Library has a great overview of the programming process.
-- Learn C Programming - Developed by Carnegie Mellon and the National Robotics Engineering Consortium specifically for FIRST, this interactive website will get your team prepared for the FIRST Robotics Competition.
7. Newer laptops no longer come with the serial port required to download code to the Robot Controller. If you have one of these laptops a solution is to use a USB/Serial converter. Various models are available at Radio Shack, CompUSA, or online, however, some models can be temperamental and they generally take longer to download than a built-in serial port (60sec vs 10 sec). Good results have been reported using: Bafo Technologies BF-810 (~$15) and a Radio Shack USB-to-Serial port cable #26-183 ($42). You can also use the converter that comes with the Radio Shack Vex Programming Kit.
8. Documentation is your friend. Take the time to at least leaf through each manual, so you have an idea of where information can be found. Most of the basic information beginners require can be found in the IFI documents or MPLAB documents available from the websites:
    • The 2004 IFI Control System Overview version applies to 2007 as well.
    • 2005 IFI Programming Reference Guide – basic how to hookup, program and download to the RC, hookup switches and sensors and do normal robot operations.
    • Useful programming and compiler documents come on the Kit provided MPLAB CBOT CD with the tool installations or are available from either Kevin Watson’s website or the legacy section of the Microchip website.
v c18_getting_started_2.4.pdf
v c18_libraries_2.4.pdf – details on timers, interrupts, and various other utility functions available to the programmer.
v c18_users_guide_2.4.pdf - table of max numbers each variable type will store, compiler options, error messages, detailed descriptions of pragmas and some other advanced topics.
v Microchip pic18f8722 data sheet - PIC assembly instruction set and details on EEPROM and other chip specific topics. Mistakes found later after the datasheet was published.
v Microchip PICmicro 18C MCU Family Reference Manual – all things great and small (in excruciating detail) about the processor we use.
v MPLAB Quick Start Guide.pdf - basic how to use MPLAB and set options.
v MPLAB Users Guide.pdf
Visit the ChiefDelphi Programming forum for discussions on all programming topics, problems, issues, and ideas.
  #63   Spotlight this post!
Unread 21-01-2007, 19:20
jesusescobar's Avatar
jesusescobar jesusescobar is offline
Jesus Escobar- PFTB-Programer
FRC #2066 (Pftb Of Doom)
jesusescobar is an unknown quantity at this point
Send a message via MSN to jesusescobar Send a message via Yahoo to jesusescobar
Im experienced in programming but im new on FRC is that an advantage???
Beware Of PFTB OF DOOM Robotics Team From EL Centro California Southwest Eagles!!!!!!!!!
http://pftbrobotics.com Our Site
  #64   Spotlight this post!
Unread 21-01-2007, 19:52
Question Re: Programming - Getting Started
I need help how can i program the robot controller to have my team number
how do i put my team number on a FRC Robot Controller
that is my question please help
  #65   Spotlight this post!
Unread 21-01-2007, 21:36
You set your team number using the binary dip switches on the Operator Interface (OI) labeled "Team Number."
--Tether the OI and RC together.
--Power up the RC (the OI will get it's power through the tether).
--Press the "Select" button on the OI three times and it will display the current team number setting. As you change the dip switches you will see the team number display also change, so it's easy to verify you've set your team number correctly.
-- The left most dip switch is the most significant bit.
Each switch is "1" if the front is pressed down and "0" if the back of the switch is down.
You can figure out the binary number of your team, or start with all the switches set to zero then beginning at the left flip the switches one at a time. If the number you get after you flip a switch to "1" is lower than your team number, keep it. If the resulting number is higher put that dip switch back to zero and go to the next one on the right.
  #66   Spotlight this post!
Unread 21-01-2007, 22:27
Sorry Marc. I didn't notice this right away.
I have some books I've taken excerpts from for the kids to read, such as
Programming Robot Controllers by Myke Predko
The Personal Robot Navigator by Miller, Winkless, and Bosworth
and some random articles I've used with students.
Obviously covering state machines, but also some behavioral programming, waypoint navigation, that type of thing.
I've found most kids respond most rapidly to programs structured as a series of lessons of increasing complexity where they can get down to experimenting with autonomous driving their first day on the job so to speak. (I purposely use robots that don't have remote controls.)
Originally Posted by marccenter View Post
Mark,
I have already looked for some articles on autonomous programming and have found a few. Do you have a favorites list or best list for less experience autonomous programmers?
I'll have to think about a favorite articles list.
  #67   Spotlight this post!
Unread 25-01-2007, 11:24
htwiz2002's Avatar
htwiz2002 htwiz2002 is offline
Htwizard
AKA: Anthony Takata Bawahawba
#1290
htwiz2002 will become famous soon enough
Wink Re: Programming - Getting Started
Originally Posted by Bored View Post
Our main programmer that did most of the work went to a different school so I'm actually going to have to learn to code C this year.
This topic is a real help thanks guys.
Originally Posted by udzap View Post
Cool this is perfect for a beginner programmer as I.
Hopefully it will help now that more than one person is doing it
TsAuKpAeTrA (Anthony)
  #68   Spotlight this post!
Unread 28-01-2007, 14:10
Mib Mib is offline
AKA: Aaron Clay
FRC #1741 (Red Alert Robotics)
Mib is on a distinguished road
Send a message via AIM to Mib Send a message via MSN to Mib Send a message via Yahoo to Mib
Originally Posted by nehalita View Post
this helped me soooo much. thank you all. this is our second yr competing and this is my first year in FIRST. i have a java background and a simple C background from 8th grade...but it was so long ago.
I'm the only one in charge of programming so when i was handed all these Cd's and codes and links and websites, i was pretty overwhelmed. i just learned about this today and I've spend the majority of the day looking through posts to answer my Q's
is there anyone here that i can directly e-mail or talk to if i have questions? (warning: I'm like a pet, i demand a lot of attn: i have questions everyday....or close to it)
also, everyone speaks about a "dongle" and i saw the picture and everything. but what exactly IS it?
its usually a piece of hardware (USB flash drive) that a program needs to be used in order for it to work
some programs allow them to be "virtual dongles" or a software dongle, but usually its a hardware device.
--------second point---------
New programmers might also check out Kevin's code and test it out. Testing and checking is a must!
Aaron M. Clay
Programming Consultent
www.GameCopyWorld.com
amclay (@) purdue.edu
  #69   Spotlight this post!
Unread 05-02-2007, 22:56
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Usually when we, here, speak of "the dongle" or "a dongle", we refer to what connects to the competition port to enable/disable the robot and turn autonomous mode on/off. You can get the schematics from http://www.ifirobotics.com or buy one from AndyMark. They should be in the kit, since they are as much a safety precaution as a debugging aid.
When talking about the USB/Serial hardware, we usually use the term "adapter" (as in a USB-Serial adapter).
We rarely use the term "dongle" to describe a license device, since none of the software teams use requires one. (Correct me if I'm wrong.)
  #70   Spotlight this post!
Unread 10-01-2008, 18:01
ProgrammerMike ProgrammerMike is offline
AKA: Michael
FRC #1804
ProgrammerMike is an unknown quantity at this point
ok, i have read all of this and it seems helpful for coding the robot in C....But we have easyC and it seems simple enough to just drag and drop and get teh code to the controller but i can't get it to do anything. I belive i have tried just about all options with it and still no results. Maybe i should give up eacyC and go with an actual C compiler. I don't know....i could really use some help....
This is my first time in any kind of robotics activity ever. Programming languages i know are VB, dark basic(not useful but jsut fun!), and a little bit of C++...Im the only programmer on my team so i really could use some help
  #71   Spotlight this post!
Unread 10-01-2008, 18:47
Don't give up on EasyC.
You just need some direction.
Easy C Pro, the version FRC teams work with has it's own forum over here: http://www.chiefdelphi.com/forums/fo...play.php?f=164
Post your questions there.
  #72   Spotlight this post!
Unread 16-01-2008, 18:51
Red Mage's Avatar
Red Mage Red Mage is offline
Owner of Holistic Omniscience
FRC #1546 (Chaos Inc)
Red Mage is on a distinguished road
Send a message via AIM to Red Mage
I believe that the name EasyC is misleading, C is not that easy.
Don't Blink. Blink and you're dead. Don't turn your back. Don't look away. And don't Blink. Good Luck.
  #73   Spotlight this post!
Unread 31-01-2008, 18:59
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
What happened to the coder's update post for '07-'08? Look at the post dates.
And does anyone know how they want us to handle the new '08 version of Autonomous Mode, with the 4-button controller? The code platform for the older versions of MPLAB and even the code in the ROBOTC package just released doesn't seem to have the codes for interfacing with the 4-button controller, just the old Autonomous Mode codes. Is this just a futile question? Am I just completely not making any sense? Please help.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
  #74   Spotlight this post!
Unread 31-01-2008, 19:04
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
You might want to try looking on the countless threads kicking about regarding the IR sensor... There should be a decent amount of information there, although, as far as interfacing the sensor, I believe it's a matter of four digital inputs and then just synchronizing the signal? Don't know, there are a lot of threads around, though.
  #75   Spotlight this post!
Unread 18-02-2008, 21:21
ROFLcopter's Avatar
ROFLcopter ROFLcopter is offline
who was phone
AKA: Robert Grizzell
FRC #2364 (Oregon RoboHawks)
ROFLcopter is on a distinguished road
Send a message via AIM to ROFLcopter Send a message via MSN to ROFLcopter Send a message via Yahoo to ROFLcopter
We have hit a programmers worst nightmare. A cyber brick wall. No communication between the RC board and the computer. It's worked before, but for some reason, it took a giant dump on itself. We are so frustrated right now most of us just feel like dropping the tools and going home...
We are using a very noob friendly program called RobotC. This program is used for VEX but has an option to be used for FRC instead. Any other compatible programming is like a foreign language and we have no clue how to use it. If anyone has a miracle, we will display your name and achievement in big letters on our bumpers.
This signature has been removed in accordance with City Ordnance law L34.B3. If you feel this signature has been mistakenly removed for reasons not within the guidelines of L34.B3. Visit the City Courthouse #3 and file a report.
Book on C programming - suggestions? wun Programming 18 14-01-2005 00:12
Help needed for getting started! chantilly_team Programming 4 27-10-2004 08:29
Autonomous Programming Competition Signup List SilverStar Programming 36 13-05-2004 15:09
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
