Go to Post ...the hardest part of engineering is communication. - EricVanWyk [more]
Unread 10-01-2008, 19:41
EduardoVemny EduardoVemny is offline
FRC #0743 (Technobots)
EduardoVemny is an unknown quantity at this point
Mounting two output sprockets on andyMark :confused:
Does anyone know if one can mount 2 of the 15 tooth sprockets provided in this year's kit with the andymark gearbox without too much hassle? If it's not so easy what would be the best way to mount two sprockets on the gearbox.
Thanks for the help
-Ed
Unread 10-01-2008, 20:23
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: Mounting two output sprockets on andyMark :confused:
I think the shaft is too short to have two sprockets on there. I'm pretty sure if you contact Andy he can get you a longer shaft.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Unread 10-01-2008, 20:36
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
looks to me like there is enough room to mount two sprockets on there, don't have one in front of me but if the keyway is long enough I believe you can fit two on there. You could always take the sprockets down a bit on the lathe if you need too, don't be afraid to make changes to the 'standard' configuration.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 10-01-2008, 21:16
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
There is enough room to fit two 3/4" width sprockets on the output shaft. If you do need a longer shaft, AM does not supply a longer shaft for the toughbox. However, if you purchase the single speed 2" longer shaft and work the short end down from 1/2" to 3/8" with a lathe (its unhardened steel) the shaft is pretty much identical to that supplied with the toughbox... except longer.
Make sure when purchasing a second set of sprockets to buy with a spline... we need to broach ours now.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-01-2008, 21:21
in between teams
AKA: Luke Van Oort
Just to clarify, you do not want sprockets with a spline; you want sprockets with 1/2" bores and 1/8" keyways. Splined sprockets refer to something completely different.
Team 1219: 2009 - Mentor
Unread 10-01-2008, 21:37
AndyB's Avatar
AKA: Andy Burchardt
Thanks for the clarification.
pic: Confused Mentor Stu Bloom Chit-Chat 18 05-02-2007 08:44
Mounting encoders to the AndyMark Joel J Technical Discussion 11 31-01-2007 21:32
Totally confused Justin Brooks Pneumatics 2 16-01-2007 15:22
mounting andymark wheels VEN Technical Discussion 10 04-02-2006 00:14
Putting two and two together... Andy Grady General Forum 13 08-01-2004 18:29
