Go to Post BEING a chairmans team is alot more important then WINNING the chairmans award. - fuzzwaz [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2008, 21:59
mrt253 mrt253 is offline
FRC #0253
mrt253 is an unknown quantity at this point
shafts for wheelbearings
did anyone get these? or are we supposed to buy them separately?
Unread 10-01-2008, 23:44
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: shafts for wheelbearings
You have to provide your own axle to mount the wheels on. The easiest solution would be bore out the kitbot holes and use Grade 8 1/2" bolts. There are already a couple other threads on here about this so you can take a look for more details on the other ideas (turning down shafts ect.)
Unread 10-01-2008, 23:49
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
We go to the hardware store and buy a length of 1/2 by 3/8 bore steel tubing and cut it to length as sleeves over the 3/8 bolts.
not so elegant but works.
Ed Barker
pic: sprockets&shafts steve0o Extra Discussion 7 08-02-2007 17:39
[OCCRA]: Modifying Shafts tdlrali OCCRA Q&A 1 30-09-2006 14:08
Torsional Deflection of shafts? coreyjon Technical Discussion 3 21-01-2005 19:02
What is your favorite method for attaching gears to shafts? archiver 2001 13 24-06-2002 04:00
5/16" cold steel shafts... archiver 2001 3 23-06-2002 23:17
