Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-01-2008, 16:30
m1k3 m1k3 is offline
FRC #1396
m1k3 is an unknown quantity at this point
roll pin into output shaft
hey guys we are trying to put the roll pin into the output shaft but we cant seem to get it in we tryed expanding the metal with heat ,oil and we already broke 2 of the roll pins we cant get it in Any other temas having problems with this
Unread 10-01-2008, 17:15
ktty_jay ktty_jay is offline
FRC #2338
ktty_jay is an unknown quantity at this point
Re: roll pin into output shaft
We're having the same problem, and totally destroyed two of the roll pins trying to get it in. Actually we order some new pins but they only come in big bunches. Like you asked before, how do you get it in? We tried hammering lightly, using a rubber mallet, and using oil as liberation.
Unread 10-01-2008, 17:39
WilkesU WilkesU is offline
FRC #1048
WilkesU is an unknown quantity at this point
Had some problems, but got what seemed like a reliable method:
1. Opened the holes a bit with a punch. This should allow the pin to fit in slightly at first.
2. Lightly tapped it in with a steel hammer, until it is set in the shaft and won't fall out.
3. Switch to a hammer with a softer head material (not too soft though), and continue tapping.
4. If the pin begins to deform or bend, shape carefully back into place with pliers or a hammer. You might have to do this a couple times.
Should work, just be careful with it and don't try to hammer it in with all your force.
Unread 10-01-2008, 17:40
pyxelz's Avatar
pyxelz pyxelz is offline
NathanParrish
FRC #0973 (Greyhound Revolutionary Robotics)
pyxelz will become famous soon enoughpyxelz will become famous soon enough
We assembled our transmissions a few days ago - the roll pin went in fine on one, broken on the other. Just make sure you get it straight before forcing it in with either a hammer or a press.
Unread 10-01-2008, 17:54
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
When putting the roll pin in, the less hits the better. If you watch the assembly video on andymark.biz, you'll notice he gets it in with about 4-5 hits. We tried it slow at first and mushroomed the head, then gave it 3 good quick wacks, WAHLAH! perfect.
Unread 10-01-2008, 19:44
Jaybee1405
Posts: n/a
I agree with Chuck, you have to do a few hard hits or else it will flatten the top. The first one went in fairly easily for me, but you have to bend it back with a pair of pliers so it stays straight. The second time, I didn't bend it back and it went in way crooked. I ended up breaking off the bent and mangled mess, and after that there was only 1 or 2 mm left on each side, which happened to be enough to hold the gear on.
Unread 10-01-2008, 21:28
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
We started it with a few light taps and finished it off with a few big hits.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-01-2008, 21:46
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
I first tried using an Arbor press which pretty much mangled the first pin, and then I used their suggestion of light taps with a hammer. It worked rather well for me, though it took awhile. It mushroomed a little bit but it went in and is holding the gear in rather well.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 10-01-2008, 22:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
maybe drill the hole out a few thou?
Unread 10-01-2008, 22:35
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
The key to getting a tight rolled pin in is to make sure it starts to fold in on itself (axial). We noticed that on end of the pin was slightly more tappered than the other. A sqeeze with pliars will encourage the fold as you smack it with a hammer. It should go in fine after that. If you don't get an overlap it just plain won't go in.
Unread 10-01-2008, 23:58
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
A really big hammer!
Our team had the same problem. We stated it with a little hammer tapping and then used a vise as a press to finish it off.
Unread 11-01-2008, 01:25
Bigflip2073's Avatar
Bigflip2073 Bigflip2073 is offline
"Chyeah"
AKA: Shane
FRC #2073 (EagleFarce)
Team Role: Electrical
Bigflip2073 is an unknown quantity at this point
Yeah we just did those today.
We just used a Vice to get the pin through the hole and then we hammered it to get it all the way through.
However the end that we hammered mushroomed we tried our best to fix it but the gear that rests on it has a slight wobble
Is that bad?
Unread 12-01-2008, 00:16
Jaybee1405
Posts: n/a
bigflip: i would just try to take a pair of pliers and break off the "mushroom head" that's making it wobble. Like I said, all you need is 1 or 2 mm on each side. The last thing you want is the gearbox to bind or jam in the middle of a round.
Unread 12-01-2008, 00:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
we stopped by the hardware store today and bought two 3/32" split pins for 32 cents including tax.
Unread 12-01-2008, 11:33
\\Zero// \\Zero// is offline
FRC #2554
\\Zero// is an unknown quantity at this point
we broke 2 of our's and now we have to buy a new output shaft since the pin broke halfway inside and is completely jamed...
Beware - transmission output shaft is not 5/8"! jskene Kit & Additional Hardware 30 13-02-2006 14:01
diameter of transmission output shaft sj31419 Electrical 5 17-02-2005 22:09
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
Securing hex shaft to drill output D. Gregory Technical Discussion 6 24-01-2003 14:05
