Go to Post This is not pinewood derby. This is not a science fair. This is a sport, and in sports there are winners and losers. - Cory [more]
Unread 10-01-2008, 22:58
LordFrz's Avatar
LordFrz LordFrz is offline
Team 2330
FRC #2330 (FTech)
LordFrz is on a distinguished road
Using More that 2 Flight Sticks
I have some questions regarding the use of flight sticks.
Can we use diffrant flight sticks that what is provided in the kit?
Are we allowed to use more that 2 flight sticks?
Will we be permitted to use something other that a flight stick?
Can we attach a battery to the mounting panel to allow the sticks to be powered without a wall adapter?
Unread 10-01-2008, 23:05
chapmatr's Avatar
chapmatr chapmatr is offline
Zippidy bling-zap whippy-wog snizin
AKA: Travis (Lead Programmer)
FRC #1676 (Pascack Pioneers)
Team Role: Driver
chapmatr is an unknown quantity at this point
Send a message via AIM to chapmatr
Re: Using More that 2 Flight Sticks
Yes
Yes
Yes
Can we attach a battery to the mounting panel to allow the sticks to be powered without a wall adapter?[/quote]
I don't think so...check the manual?
Did you know that 87% of all online statiscs are made up?
Unread 10-01-2008, 23:07
LordFrz's Avatar
Team 2330
FRC #2330 (FTech)
Thanks that cleared up some things our team was wondering about.
Unread 10-01-2008, 23:08
chapmatr's Avatar
Team Role: Driver
Cool Re: Using More that 2 Flight Sticks
No problem, glad to help. Yeah, we build a new control box every year of the operator (arm, ramps, etc.)
If you guys need any coding help, drop me a line.
Unread 10-01-2008, 23:23
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Yes
Yes
Yes
They can power the OI with a 9V battery if they want a portable OI for demonstrations, but they must realized that during competition, all connections to the robot go through the Competition port, including the power to use the OI. So the answer the question:
In Competition: No
At School: Yes, but notice that any voltage changes will cause your analog sensors to mess up on your OI like your joysticks, so be careful, and I highly advice you to make a voltage regulator that will ensure a steady voltage.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 11-01-2008, 00:27
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
The OI has an internal LM7805 or similar regulator IC. Voltage input is already regulated.
Unread 11-01-2008, 07:19
LordFrz's Avatar
Team 2330
FRC #2330 (FTech)
Thank you all for your input. It was very helpful.
Unread 11-01-2008, 10:41
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
One more thing to add: If you're using something like the USB Chicklet (http://www.ifirobotics.com/usb-chicklet.shtml) on your operators console, there is no place to plug it in, and you MUST bring a battery for it to the competition. the OI gets it's power from the "competition" port, but no other independently powered devices will!
Unread 11-01-2008, 21:27
RyanN's Avatar
RyanN
If it is regulated, then the regulator is not very good... Last year we hooked up 2 9V batteries in parallel (so the total voltage was still 9V) but all of our analog stuff was messed up.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 11-01-2008, 21:38
DonRotolo's Avatar
Back to humble
FRC #0832
Voltage regulators have a parameter called "Dropout"- the input voltage at which regulation no longer occurs.
A 78xx series regulator requires an "overhead" - the voltage difference between input and output - of something like 2 or 3 volts to avoid dropout. Low-Dropout (LDO) regulators exist, with overheads of a fraction of a volt.
Your 9 volt transistor battery was very close to the dropout limit for a 7805 regulator already. If you draw more current from the battery tha its rating - I think it's 20 mA for that kind of battery - the battery output voltage can sag (get lower). You may want to check what current the OI draws, either by looking at the specs or by direct measurement, and decide if a two 9 volt batteries in parallel is sufficient to power the OI reliably.
Don
using more motors Aren_Hill Motors 6 13-02-2005 17:44
using more motors Aren_Hill Technical Discussion 2 13-02-2005 15:52
Using the edu--erm, Robovation for more info? Billfred Control System 8 18-07-2004 21:50
Is 'using a smaller cylinder' really that easy?? mjt902 Pneumatics 4 29-01-2003 16:13
