Go to Post You can sometimes step outside the box if you have properly thought through the question. - Jim Zondag [more]
Unread 11-01-2008, 01:17
CraigHickman
Posts: n/a
Re: Wheel size
We're planning on using the round ones. But yeah, 4 inch. There's no need for larger, to keep gearbox weight/size down.
Unread 11-01-2008, 01:22
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: Wheel size
You might want to use smaller wheels to help keep your cg down low. Since there aren't ramps to climb in this game, big wheels don't really have an advantage. You can get the same speed and torque with any wheel size by changing the gear/chain reduction. Smaller wheels also leave more room on the bot for other things, like a giant game piece. We're planning on 6" wheels, maybe 4" on the front.
Unread 11-01-2008, 01:23
AdamHeard's Avatar
Lead Mentor
Re: Wheel size
4" on 294, 6" on 973.
Unread 11-01-2008, 01:25
JanTM1191 JanTM1191 is offline
AKA: Jan Mariak
FRC #0369 (Nuts 'n' Volts)
Team Role: Driver
JanTM1191 is an unknown quantity at this point
Send a message via AIM to JanTM1191 Send a message via MSN to JanTM1191
Re: Wheel size
The problem is that we're using the kit frame with live axles, and we had to flip it over because the bearings wouldn't fit because of the indent on the frame and if we used smaller wheels it would be too low to the ground.
Unread 11-01-2008, 01:34
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Wheel size
6" this year. Same wheels as last year for the drive ones, completely custom ones for the non-drive ones.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 11-01-2008, 02:06
nirty's Avatar
nirty nirty is offline
FRC #1574
nirty is an unknown quantity at this point
Re: Wheel size
we use home made weels so we get maximom track but you always remmber
it depand what you need speed or stragh becose the size metter
Unread 11-01-2008, 08:42
Billfred's Avatar
Billfred Billfred is offline
Re: Wheel size
6" for the Capitals. We can drop about a half-inch if need be, but we'll cross that bridge when we get to it.
Unread 11-01-2008, 08:54
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Wheel size
We've rolled on 4s the last two years and have a design to make them that so simple light and strong we don't see the need to change them. We never saw a loss in speed going that size, we're usually pretty fast, or pushing power when needed.
Thank-you 294 & 67
www.bobcatrobotics.org
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
Wheel size poll sanddrag Technical Discussion 15 25-05-2006 15:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Calculating Wheel Size phrontist Technical Discussion 15 07-09-2004 18:55
Calculating Wheel Size To Climb Yan Wang Math and Science 12 18-01-2004 22:49
