Go to Post Physical items will be lost along the way eventually but memories will never be forgotten. - Connor McBride [more]
Unread 10-01-2008, 20:09
Ryuzaki Ryuzaki is offline
None #1388
Ryuzaki is an unknown quantity at this point
quick dewalt transmission dissasembly question
the Carrier Sun Gear in the dewalt transmission has four posts on it for the planetary gears. These need to be removed, but are extremely hard to do so. The dewalt white paper says nothing about them. Am I missing something?
Unread 11-01-2008, 01:45
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: quick dewalt transmission dissasembly question
How are you trying to remove them, and why do you want to do so?
If you've removed the last stage and are planning to install the plastic spacer, consider drilling four holes in the spacer, and using those pins to align it.
If you really want to be rid of them, use a grinding wheel on a rotary tool, and cut them off. It's been a while since I played with a DeWalt transmission, but I suspect that the sun gear, planet carrier and pins are a single sintered powder metal piece, so you can't press them out. Edit: See Fred's correction below.
Unread 11-01-2008, 01:49
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
They are not a single piece. You can press them out - we used hardened steel pins of slightly smaller diameter to press them out with an arbor/drill press, and then we drilled out and countersunk the holes for a bolt pattern.
Drawings/Model of DeWalt Transmission sanddrag Inventor 30 23-12-2008 19:01
DeWalt Transmission questions StevenB Technical Discussion 22 14-02-2007 16:02
Dewalt transmission problems? roach1051 Technical Discussion 10 11-04-2006 00:33
DeWALT Transmission After Action Report CyberWolf_22 Technical Discussion 7 17-04-2005 00:28
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
