Go to Post I mean who does want to write their code like this... [CODE] CANHAZ.VICTOR; GIMME.VICTOR; VROOMVROOM.VICTOR(1); KTHNXBAI; [CODE] - JohnFogarty [more]
Unread 11-01-2008, 01:12
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: Disengaging a motor on a spring powered hurdler
Why not mount a winch so it can spin freely, then use dog gears to engage/disengage it?
Unread 11-01-2008, 01:46
CraigHickman
Posts: n/a
I like your idea about the shifters. Andymark makes planetary gearboxes that changes the output of a Fisher-Price motor into that of a CIM. Two FP's Into that, into a Gen2 with one of the speeds taken off should be plenty of force to compress a decent spring, assuming a post gearbox reduction. It all comes pre-made, takes little modification, and is actually quite light.
Unread 11-01-2008, 01:51
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by jfrank View Post
i don't think you are allowed to store energy (like in a spring)
You are allowed, as long as it's safe. See <R01> and <S01>. (That's a subjective call, and the officials will make their ruling based on design and operation.)
Originally Posted by corpralchee View Post
Don't they make pneumatic cylinders only use air in one direction. Single action acting cylinders I believe... Anyways you could use that to pull the spring back, let out the air and the spring expands.
Those are prohibited by <R89>, because they do not share part numbers with the items on the Free Pneumatics Order Form.
Unread 11-01-2008, 08:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We are planning a pneumatic actuated catapult, and will also have to figure out how to unlatch it, because it will start with the cylinders full of pressure, and halfway extended. The latch will have to release the catapult against full force of what will probably be two 2" bore cylinders. However, the cylinders will probably be located relatively close to the pivot, and the latch can be located at the opposite end, so this will give the latch mechanism quite a bit of leverage. We can also add more leverage by making the latch a lever, actuated by a long stroke, small bore cylinder. I think it will work out ok, but we'll see today if we can draw up a design and run some numbers.
also one could use a steel pin that engages two holes in the parts, and the part with these holes could be made of a plastic material, with a low coefficient of friction. This might make it easier release the mechanism. It could be used on a motor design, by having the pin go sideways into a rotating plate. You would want it to be rather large in diameter, to get the force down to a reasonable level.
hurdler or herder? XXShadowXX Technical Discussion 17 08-01-2008 17:16
RC Powered on 7.2v backup chris31 Electrical 10 17-10-2006 11:02
Gas powered engine horsepower equivalent to electrical motor horsepower? Elgin Clock Motors 30 22-08-2004 20:44
Bosch Drill Motor Clutch Spring Dimensions?? aaronbr28040 Motors 3 18-02-2004 19:52
Powered OI input EricS-Team180 Programming 7 28-09-2003 21:23
