Go to Post We've been thinking about just declaring our smallest kid on our BOM and making her part of the robot. - Qbot2640 [more]
Unread 11-01-2008, 02:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Banebots 540 and 550 motors
Has anyone used these successfully in the past?
If so, in what application?
Did they perform as advertised? Were they reliable? Were you satisfied with them?
Thanks,
-Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 11-01-2008, 03:15
AdamHeard's Avatar
Lead Mentor
Re: Banebots 540 and 550 motors
I've used them for non FIRST applications.
They are pretty much similar to FP motors; Although they are less powerful (but you can tell from the specs already) and burn out much easier at stall.
So, just like the FP motor. If you accept their limitations, they are a nice powerful motor that can be easily mated to many different gearboxes.
Unread 11-01-2008, 08:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We used the BB motor that came on the 64:1 gearbox to power our arm last year. We bought a 125:1 gearbox to get more reduction, then used it to drive a chain system with a further 8:1 reduction. This was used to raise and lower a long arm which gripped the tube on the end. It worked fine thru 2 regionals, and in demonstrations over the summer, and is still working. No smoke from the motor. We bought several replacements, but never needed to use them. Our arm was designed with a gas spring to support most of the weight, and we were always careful to not stall the motor. If you take these design precautions, the motor should be fine. If you treat the motor like a CIM, you'll probably smoke it.
Unread 11-01-2008, 08:46
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We used them before and had some unusual performance drop that made it appear like burned out a single pole. Once we figured it out and replaced it the motor was fine.
I would de-rate the banebots numbers on them a bit based on our experiences as well. The advantage to using them is they are cheap to replace < $6 each and for around $30-40 from Banebots they have planetaries are available in many ratios for these motors making them easy to adapt to a mechanism without much effort.
Thank-you 294 & 67
www.bobcatrobotics.org
pic: Presenting Teams 384, 540 and 1086 Crebb Robot Showcase 28 12-03-2007 08:04
Small Banebots Motor Issue - Lessened torque and smoke sanddrag Motors 10 12-02-2007 21:41
Which pinions for FP motors and BaneBots 42 mm gearboxes? Madison Technical Discussion 3 23-01-2007 20:04
Are all banebots motors allowed? EnderWiggin Motors 7 11-01-2007 22:27
Motors.. and more motors.. How many on your 2004 bot? OneAngryDaisy Motors 33 23-02-2004 00:46
