Go to Post (Water on all this would be good too) - buildmaster5000 [more]
Unread 10-01-2008, 09:58
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Bumpers
Originally Posted by IndySam View Post
I have never seen anything in the rules that says you can't but why would you want to?
The weight is not counted in the 120lbs and you want as much weight as possible down low.
With the rules requiring standard bumpers covering 2/3rds of the robot, if someone wanted a playing configuration of say 38x60x unlimited (think flop bot) you may have to find ways to lighten the bumpers. We have never had weight problems using standard bumpers, however, by adding 42 inches per side and if you want bumpers all the way around, bumper weight weight could cause a probelm. I did not see anything this year regarding "custom" bumpers being allowed, only that "standard" bumpers must cover 2/3rds of your robot.
Unread 10-01-2008, 09:59
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Bumpers
No one says you have to use the full 120lbs of robot weight either.
Do yourself a favor and take advantage of the 15lbs of bumpers, and spare weight with your actual robot construction if you really want to go for speed this year.
You will be happier in the long run... (or final lap so to speak).
Unread 10-01-2008, 10:03
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Bumpers
I thought you weren't allowed to modify the design, but that may have been when the bumpers were first introduced. I know I saw teams last year at Pittsburgh who had done that very thing. They had used Forrester bits and drilled lightening holes in the back of the plywood. I don't recall if they had to rebiuld them or if they were ok to use.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 10-01-2008, 10:05
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Re: Bumpers
If this game is anything like NASCAR [rubbins racing], there is going to be bumper material all over the field.
Is Shop Vac our new sponsor?
I personally think bumpers should be optional. I don't care to spend all that time fixing bumpers, removing them to work on the robot and getting inspected multiple times. This is an engineering problem and we should be able to design robots that don't need bumpers. If you can't hang with the big boys then put on some bumpers. Prior years I think teams used them for the weight advantage they gave, I don't think this year the weight will help, but will hinder you.
Just say no - to bumpers - and drugs.
Unread 10-01-2008, 10:32
Billfred's Avatar
Billfred Billfred is offline
Re: Bumpers
Originally Posted by corpralchee View Post
But you only have 15lbs for the bumpers and the less weight on your robot the faster it will be.
More precisely, it'll help with acceleration immediately. With a little re-gearing (or, for many teams, re-sprocketing), you can certainly get more top speed at the expense of that newfound acceleration.
The way I see it, pesky added-on requirements tacked on by people or organizations that you're in no position to argue against are a part of life. (There's probably some crack I'm supposed to make as a Mac user about Vista in there, but I'm missing it this morning.) You play the cards you're dealt, keep your bumpers light, and focus on getting around the track as fast as you can.
Unread 10-01-2008, 10:38
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Re: Bumpers
I'm just looking to reduce the total weight of the robot for acceleration and cornering. I'm not trying to get around the rules. I do not intend to compromise the integrity of the bumpers. I just want to reduce the weight of the robot.
My other thought was to make my own plywood from balsa and sandwich it between to 0.010" pieces of aluminum. The rules do not specify the type of plywood we have to use.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
Unread 10-01-2008, 10:51
AKA: Kevin
Re: Bumpers
Good point, but bumpers got on our robots because people complained. USA = freedom of speech. Bumbers have been a big deal for some time, the first year I think they had to be included in the weight and the last 2 years they where a bonus for teams. Now we are being forced to use them. I believe the time wasted on them could be used so that the students learn more. We are going the wrong way by being forced to use them. Sorry I inconvenienced you and made you read what I wrote. It all fun, have a good day.
Unread 10-01-2008, 12:21
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: Bumpers
Maybe there should be some flexibility in the design. If you are using a catilever design on the wheels then the 3/4" plywood could be a requirement. If you are using bracketed wheels with an outside plate, maybe the plywood is optional but the padding is not.
My understanding was that you could use the kit box design with no weight penalty (allowed 15 lbs) but if you designed something different then you have to add this into the overall weight of the robot (120 lb max).
anyone know if this is true?
Unread 10-01-2008, 14:53
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumpers
<R08> Teams are required to use STANDARD BUMPERS on their ROBOTS....
See the rest of the rule for what you MUST do.
(since 2004)
Unread 11-01-2008, 09:02
Engineer's Avatar
KØBR
AKA: Rick - KØBR
Re: Bumpers
Yes, but there is no mention that you can't modify the plywood i.e. drill holes to remove weight.
Hello, from KØBR.
RE: bumpers archiver 2000 0 24-06-2002 00:13
Bumpers archiver 2000 2 23-06-2002 22:48
Bumpers? archiver 2000 3 23-06-2002 22:32
Bumpers archiver 2000 0 23-06-2002 22:32
bumpers Martin Rules/Strategy 2 13-01-2002 21:51
