Go to Post Woo for speculation! - Eugenia Gabrielov [more]
Unread 11-01-2008, 09:31
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Can't mount the gear tooth sensors
The new AndyMark gearboxes are different from the 2006 version and I can't seem to figure out how to make the gear tooth sensors fit.
Using 0.75 inch standoffs I can make the board just fit, but it rubs against the gear--unacceptable.
We followed the AndyMark gearbox instructions and the gears look correct, but this year the gear to be sensed is not up against the cover.
Did I miss something simple?
Thanks in advance.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 11-01-2008, 12:09
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
Re: Can't mount the gear tooth sensors
Since the holes in the plastic plate didn't give the proper spacing, I decided to drill holes in the aluminum plate. Mounting to the Al plate removes the need for stand-offs and results in a more robust mounting.
The board will not fit as supplied. I trimmed the back corners off of the board so it would fit in the space in the corner of the gearbox.
Using a 1 mm thick piece of cardstock between the sensor and the gear, I marked the hole locations on the aluminum plate and then drilled holes for #8 screws.
Be sure you use PLASTIC washers under the board or you will get short circuits to the gearbox. Don't use metal washers as shown, I had to remove them later when I didn't have the camera.
When finished the sensor worked great. You MUST power it with both 5 and 12 VDC or it will not work. We chose to use a 4-conductor cable instead of the expensive PWM cables.
ID:	5971  Click image for larger version
Unread 11-01-2008, 12:44
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Tim, Excellent post!!! The pictures speak a thousand words. I was considering doing the same to ours, and now I see it finished already! All I can say is SWEET!
Unread 11-01-2008, 14:28
Is your clear cover plate perhaps upside down?
Unread 11-01-2008, 18:16
Armando Gonzalez's Avatar
Armando Gonzalez Armando Gonzalez is offline
FRC #1872 (Yellow Fever)
Armando Gonzalez has a spectacular aura aboutArmando Gonzalez has a spectacular aura about
Send a message via MSN to Armando Gonzalez Send a message via Yahoo to Armando Gonzalez
One lil question, don't the gears need any lubrication?
Armando Gonzalez
Team 1872 - Yellow Fever
San Juan, PR
Awards
Rookie Inspiration Award - 2006 UCF Regional
Unread 11-01-2008, 18:18
The_Laughing_ManMII's Avatar
The_Laughing_ManMII The_Laughing_ManMII is offline
FRC #1361 (The Nightmares)
Team Role: Driver
The_Laughing_ManMII will become famous soon enoughThe_Laughing_ManMII will become famous soon enough
maybe, maybe not, it depends on the material used for the gears
The question is not how far you must go, but how far you will be willing to go to achieve that what is needed. - Father from the Boondock Saints
Unread 11-01-2008, 18:49
Wow, thanks for the info.
Armando Gonzalez
San Juan, PR
Awards
Unread 11-01-2008, 18:51
tails9889's Avatar
tails9889 tails9889 is offline
FRC #1006
tails9889 is an unknown quantity at this point
Question re: hybrid mode rule (autonomous)
i'd like to talk about how if in hybrid mode can u go counter clockwise even if u r not allowed in teleoperated mode
Unread 11-01-2008, 19:20
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
It's hard to tell. The two holes for the sensor are not symmetrically oriented to the shaft that the gear rotates on--therefore only one board orientation will work.
If the plastic plate is upside down, couldn't you fix that by simply flipping the GTS board over? We tried many ways and the closest we found was pointed right at the gear, but about 1 mm too close. I have not heard if anyone else has had the same problem.
Maybe we missed something, but now that the new holes were drilled in the Al cover (I didn't want to try drilling in the Lexan for fear of messing up) the board seems to work fine.
Unread 11-01-2008, 19:26
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
We put a small amount of white lithium grease on the two gear pairs. You need something on the gears or they will grind themselves into shards.
We purchased the grease at a local hardware store. Just about any heavy grease will work. Just use enough to give the gears a light coat.
Unread 11-01-2008, 19:31
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
You're welcome! I agree that more posts should be clear, detailed solutions. Giving back constructively to this community is a responsibility for all of us who take from it.
Good luck and I hope to see you in Atlanta!
Unread 11-01-2008, 20:51
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
I mounted mine to the clear cover. This is the first time i have used these sensors. They seem to be pretty far away from the gear when mounted. The picture seems to indicate that they read from the end and not the side. Not for sure if i am mounted right.
Unread 14-01-2008, 21:15
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Did you have to add some spacers between the gear tooth sensor and the Polycarbonate so it reads the output gear???
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 15-01-2008, 01:59
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I'm curious about this as well. Can a gear tooth sensor work from what seems to be around 3/4" to 1" away from the gear?
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 15-01-2008, 18:52
I could not get a reading today. We are going to download the new easy c codes to see if that helps, since it is a different sensor from last year. We have never used this before and not for sure if we are even wiring it correctly. Where can we find information about where it is suppose to mount and how to wire it.
Help with the Kit Gear Tooth sensors Keo-san Programming 9 20-02-2007 08:07
dumb question: Where do we get the gear tooth sensors from? waialua359 Programming 6 30-01-2007 22:45
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Gear Tooth Sensors et1337 Electrical 7 28-01-2006 22:48
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
