Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Unread 11-01-2008, 10:02
GaryVoshol's Avatar
Cogito ergo arbitro
Re: timing of re-contact
You're vaulting the robot over the overpass? I'd like to see that! No, on second thought, I wouldn't want to. I'd need more than eye protection to protect from all the flying shrapnel.
(since 2004)
Unread 11-01-2008, 10:23
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
I think if you could jump over the overpass reliably and consistantly, they would give you double points just for the heck of it.
But I too would be doing a "duck and cover" move to avoid the flying parts.
Unread 11-01-2008, 10:31
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by Gary Dillard View Post
If my robot vaults over the overpass...
As would I!
Gary, if your team does end up doing this, expect me to at least visit you during The Champs. @ Atlanta, or make my way to the FL regional somehow!
Keep us posted!
Unread 11-01-2008, 10:43
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Wouldn't it be kind of hard to keep your standard bumpers within the bumper zone? I would love to see you do it! I suppose some type of climbing robot could do it as long as you didn't grab the overpass and just layed across it.
EDIT: To answer your question, probably doing it after you land as long as it is before the trackball goes over the opposing alliances finish line. Could maybe be the same action since you can not possess the trackball when you do that either.
Unread 11-01-2008, 10:44
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I think the generally accepted interpretation of the rules for hurdling would tell you to release the ball while still in the air, and make sure it hits the ground before you re-contact it. The only possible point of dispute with that might be the rule about remaining in contact with the ball while crossing the finish line gives you no points, so you might have to release it before you cross the line...
Unread 11-01-2008, 12:29
GaryVoshol's Avatar
Cogito ergo arbitro
That rule doesn't apply to hurdling - see Update 1
(since 2004)
Unread 11-01-2008, 13:16
ALIBI's Avatar
FRC #0141
Team Role: Parent
If you are concerned about giving up possession of the TrackBall, why not have your robot pass the TB over the overpass and pull it back? From the Q and A:
"A robot may break all contact with the Trackball as it passes over the Overpass. Likewise, a robot may be in contact with the Trackball when it passes over the Overpass. Either would be considered a valid Hurdle."
I can think of four or five ways to do this (or something similar). Of course, since the kids have only decided on their drivetrain at this point, I must keep those ideas to myself for now.
autonomous timing seanl Programming 6 09-03-2007 09:42
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
Distance timing out bludstayne Programming 5 05-03-2004 13:47
Timing Codes Ryan Cumings Programming 11 29-01-2004 22:26
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
