Go to Post Conspire to Inspire despite what may transpire ! - Bill_B [more]
Unread 11-01-2008, 09:27
RedOctober45 RedOctober45 is offline
Mentor - Embedded Software Engineer
FRC #0291
RedOctober45 will become famous soon enoughRedOctober45 will become famous soon enough
Send a message via AIM to RedOctober45
PIC microcontroller mappings?
Is there any documentation that has the pin mappings of the actual PIC microcontroller to the control module pins (or whatever you call it)?
Thanks!
Unread 11-01-2008, 10:12
Re: PIC microcontroller mappings?
bear24rw already pointed you to http://kevin.org/frc. On that page, there is a "robot_controller_signal_map.pdf" which should be what you want.
Unread 11-01-2008, 10:19
FRC #0291
oops, sorry, missed that one. but thanks though!
Unread 11-01-2008, 18:47
psh psh is offline
FRC #0166 (Chop Shop)
psh is on a distinguished road
Thanks!
If I am not mistaken, the robot controller is really two PIC processors with one shell casing. The pins you see outside represent a superset of the two processors, with the caveat that the pins tied to the master processor have an inherent latency governed by the cross communication taking place between the two using FRC software. As a FIRST developer your software lives in one of the processors and so you only have direct control over the pins wired to that processor. The other ones are "remote" pins.
>Per
Unread 11-01-2008, 22:22
Kevin Watson's Avatar
La Cañada High School
FRC #2429
>Per
With the exception of the first twelve PWM ports, all external I/O is controlled by the user/slave processor.
-Kevin
Kevin Watson
http://kevin.org
Unread 11-01-2008, 23:53
FRC #0291
hmm didn't really know that but that helps
Private bot - which PIC microcontroller? 3dude_2231 Technical Discussion 29 19-12-2007 18:22
Dead microcontroller :-( ManicMechanic VEX 2 24-11-2007 22:57
Embedded Microcontroller major? John Gutmann Career 5 27-07-2006 23:49
Propeller Microcontroller Adam Y. Electrical 4 20-04-2006 13:27
microcontroller selection¿ Rickertsen2 Programming 11 25-05-2003 10:52
