Go to Post ...why do programmers have a nesting habit? - Andrew Schreiber [more]
Unread 11-01-2008, 12:33
G1279's Avatar
G1279 G1279 is offline
Liam
FRC #1279 (Cold Fusion)
Team Role: Operator
G1279 is just really niceG1279 is just really niceG1279 is just really niceG1279 is just really nice
2008 Easy C Pro
Downloaded to our new labtop (sadly running on vista) Havent had any problems yet but I've noticed that icons and robot computer board are for Vex. Is it still compatible with FRC or is there something I have to change/get/download? Any help will be great. Thanks
VCU Regional 1st Seed
NJ Regional Winner (+103, 375)
-2006
NJ Regional Winner (+103, 25)
-2008
NJ Semi-Finalist
Unread 11-01-2008, 12:42
Jessica Boucher Jessica Boucher is offline
FIRST Historian
Jessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond reputeJessica Boucher has a reputation beyond repute
Re: 2008 Easy C Pro
Hi Liam,
You just need to switch it over to the FRC Controller of your choice. Go to "Options", then "Robot Controller Setup". You'll see a window open with two dropdowns. From there, change the Robot Controller to "FRC", and then make sure the 2nd dropdown has "FRC 2006 - 2008" selected.
Good luck!
JAB
jessicaboucher.com
FRC Alum, Mentor, Volunteer, lots of things.
Championship Volunteer of the Year, 2016
Advisor, NE FIRST
Unread 17-01-2008, 13:01
G1279's Avatar
Liam
Team Role: Operator
Re: 2008 Easy C Pro
*slaps forehead* Thanks, just noticed that not to long after the post. Thanks for the reply.
-2006
-2008
NJ Semi-Finalist
Easy C Pro RRA4LIFE2 Programming 6 16-01-2008 17:25
Source code for the Easy C Pro library functions? bobpskier Programming 3 05-02-2007 21:39
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
From MPLAB To EASY C PRO 354.FIRST Programming 4 30-01-2007 17:13
