Go to Post I am a firm believer that there is no model that can be transplanted/copied from one team to another and have the same level of success. There just isn't a formula for it. The mindset you should have is: "I know I have made a positive impact on my community". - tim-tim [more]
Unread 11-01-2008, 12:44
Re: Wiring pressure switch
Originally Posted by m1k3 View Post
do you soder the pwmto the prongs
Use a crimp connector on the end of the PWM cable that attaches to the switch. Since the PWM cable is #24 wire or smaller, simply strip back about an inch of the insulation and fold the wire over twice. This will give you an equivalent wire size somewhere between #18 and #22, just the right size for a small crimp.
Never solder to the RC, use the female RC connector supplied with the PWM cable.
pressure switch wiring question... Transformers Pneumatics 11 16-02-2008 12:55
Pressure Switch Wiring idahorobot Electrical 1 27-01-2007 11:18
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
Pressure Switch Wiring Question Matthew_H Electrical 4 16-02-2004 01:25
Pressure Switch Wiring Question Matthew_H Control System 1 08-02-2004 15:28
