Go to Post "One man's trash is our robotics team's fundraiser" (We have an aluminum can drive to raise money) - bombadier337 [more]
Unread 11-01-2008, 13:10
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Ultrasonic rangers for obstacle avoidance
For our team's hybrid mode, I've been thinking of using data from four ultrasonic rangers, one on each side of the robot, in conjuction with known distances accross the field, to detect obstacles.
I have to questions about this:
- First of all, is this a valid concept? I can explain in more detail, if necessary.
- Secondly, what beam width should we look for for optimal performance? Maxbotix's LV-EZx (which seem to have worked well for several teams) sensors come in configurations of 4 different beam widths -- from my research, it would seem that the LV-EZ4, with the longest beam width, would be most effective, but I would like to be sure before we buy any.
Unread 11-01-2008, 13:20
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: Ultrasonic rangers for obstacle avoidance
aahh young padawon( I say this cause this is what Ive been doing for the last week day in day out hour in hour out). yes it is a valid concept.
the things you will want to look at are . . finding the right shape of sensor set up vs your drive chain. little hint unless your a crab drive think stop sign not street sign. as far as what sensors to use and beam width . . well think of the shape of your chassis vs the blind spots each beam will have. you also may want to think about mixing brands of sensors . . will some places on your bot not need much coverage while others not so much? . . that sort of thing.
and as to not take away any of the fun your about to have Ill leave any more hints and tips to PMs if you want/need some help.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 11-01-2008, 13:40
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
As far as I know they are legal this year. I also know that the Bomb Squad (Team 16) used them last year and they could sense the "spider feet" with them in automode. We're considering using them for more than one function...
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 11-01-2008, 15:00
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Team95 has used these and infrared ranging sensors in the past, with mixed results. They generally work (although IR works pretty well for bot avoidance, it's bad if the stuff you're looking for is polished diamond plate), but there are a lot of little gotchas (like ultrasonic sensors getting false readings from loud noises like pneumatic valves). Testing is the order of the day.
Unread 11-01-2008, 17:43
Mib Mib is offline
AKA: Aaron Clay
FRC #1741 (Red Alert Robotics)
Mib is on a distinguished road
Send a message via AIM to Mib Send a message via MSN to Mib Send a message via Yahoo to Mib
We're thinking about mounting 2 of them at the corners of our bot, so we can sense the wall. Maybe just run around the track as one of our hybrid modes (1ish laps), and turning based on objects intersecting. We're also mulling over the possibilities of one mounted on the head to detect objects strait in front of us (other robots, walls, etc).
But realistically, I don't think it's feasible to safely navigated near the opponents during the hybrid mode. Also, as a saftey feature, we're considering one button be designated towards 2-5 second slowdown..pause...speedup phase so we can avoid hitting other robots.
Aaron M. Clay
Programming Consultent
www.GameCopyWorld.com
amclay (@) purdue.edu
Unread 11-01-2008, 19:22
Ubuntu User
AKA: Brian
Thanks for the insight guys. I think we'll order one Maxbotix LV-EZ0 (the widest beam width), and then order additional ones if testing goes well.
GDC likes Power Rangers? dtape Rumor Mill 7 05-01-2008 18:38
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
Collision avoidance during autonomous Andrew Schuetze Programming 5 17-01-2006 13:24
Segway has obstacle in Japanese market Robb Gerber Dean Kamen's Inventions 10 10-11-2002 23:08
