Go to Post if you want to repay us for the omni-wheels, use the money to help out a few rookie teams next year. Buy them batteries or help build them bumpers, anything you see fit will be much better than cash back to us. - AllenGregoryIV [more]
Unread 11-01-2008, 13:16
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: timing of re-contact
If you are concerned about giving up possession of the TrackBall, why not have your robot pass the TB over the overpass and pull it back? From the Q and A:
"A robot may break all contact with the Trackball as it passes over the Overpass. Likewise, a robot may be in contact with the Trackball when it passes over the Overpass. Either would be considered a valid Hurdle."
I can think of four or five ways to do this (or something similar). Of course, since the kids have only decided on their drivetrain at this point, I must keep those ideas to myself for now.
autonomous timing seanl Programming 6 09-03-2007 09:42
Timing Belt Clamp shorton Technical Discussion 10 18-07-2006 22:50
Distance timing out bludstayne Programming 5 05-03-2004 13:47
Timing Codes Ryan Cumings Programming 11 29-01-2004 22:26
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
