Go to Post Either you have it hooked up wrong, or you have the Battery of the Gods. Probably filled with Mountain Dew... - nighterfighter [more]
Unread 11-01-2008, 15:00
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Ultrasonic rangers for obstacle avoidance
Originally Posted by pogenwurst View Post
For our team's hybrid mode, I've been thinking of using data from four ultrasonic rangers, one on each side of the robot, in conjuction with known distances accross the field, to detect obstacles.
I have to questions about this:
- First of all, is this a valid concept? I can explain in more detail, if necessary.
Team95 has used these and infrared ranging sensors in the past, with mixed results. They generally work (although IR works pretty well for bot avoidance, it's bad if the stuff you're looking for is polished diamond plate), but there are a lot of little gotchas (like ultrasonic sensors getting false readings from loud noises like pneumatic valves). Testing is the order of the day.
GDC likes Power Rangers? dtape Rumor Mill 7 05-01-2008 18:38
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
Ultrasonic will not work with another Ultrasonic plz help Jackel148 Programming 10 10-05-2006 15:31
Collision avoidance during autonomous Andrew Schuetze Programming 5 17-01-2006 13:24
Segway has obstacle in Japanese market Robb Gerber Dean Kamen's Inventions 10 10-11-2002 23:08
