Go to Post Stop. Breathe. Relax. QUIT STATING STUFF THAT YOU DON'T KNOW TO BE TRUE. - Rich Kressly [more]
Unread 11-01-2008, 16:40
taggartbg taggartbg is offline
FRC #1712 (Dawgma)
Team Role: Electrical
taggartbg will become famous soon enoughtaggartbg will become famous soon enough
Send a message via AIM to taggartbg Send a message via MSN to taggartbg Send a message via Yahoo to taggartbg
SetPWM and our IR controls
Hey everybody,
So I got the IR board programmed, got it all wired up to interface with the bot, coded it all out, and nothing happens. I currently only have one of the pins on the board (pin 5) running into the Digital In/Out (signal pin 1). I'm trying to get this working on a two-motor tank-drive bot with the '07 microcontroller. Here is my IR code:
void OperatorController (void )
unsigned char ir1;
unsigned char ir2;
unsigned char ir3;
unsigned char ir4;
while ( 1 ) //I'm pretty sure I need this while loop, yes?
Tank2 ( 1 , 2 , 2 , 2 , 1 , 2 , 0 , 1);
ir1 = GetDigitalInput ( 1 ); //this should return "1" if it is getting signal, yes?
ir2 = GetDigitalInput ( 2 );
ir3 = GetDigitalInput ( 3 );
ir4 = GetDigitalInput ( 4 );
if ( ir1 == 1) //turn left at half speed
SetPWM ( 1 , 65 );
SetPWM ( 2 , 192 );
continue; //do I need this?
else if ( ir2 == 1) //straight at half speed
SetPWM ( 1 , 192 );
SetPWM ( 2 , 192 );
else if ( ir3 == 1) //turn right at half speed
SetPWM ( 1 , 192 );
SetPWM ( 2 , 65 );
else if ( ir4 == 1) //backwards at half speed
SetPWM ( 1 , 65 );
SetPWM ( 2 , 65 );
else //all stop
SetPWM ( 1 , 127 );
SetPWM ( 2 , 127 );
continue; //again, do I need this?
After a few attempts and nothing happing on the bot, I decided to try this simple code to start picking peice by peice what works and what doesn't:
while ( 1 )
SetPWM ( 1 , 192 );
SetPWM ( 2 , 192 );
In theory, that should make the motors start moving forward at half speed yes? Well it just sits there doing nothing.
I was hoping someone could identify what exactly I'm doing wrong, as I am getting zero results from my bot.
Thanks,
/Taggart, team 1712
help us program our controls dude_brd Programming 1 10-02-2007 12:02
need help on programing our controls dude_brd Programming 1 07-02-2007 18:42
FRC: Reset and Program Controls yanksrock777 General Forum 4 24-01-2007 22:37
Push Button and Switch Suppliers for OI controls Goldberg204 Control System 8 11-01-2007 15:27
pic: 383`s controls and driver Manoel Robot Showcase 13 03-03-2005 00:57
