Go to Post I feel like I need to rinse out my brain with drain cleaner - dlavery [more]
Unread 11-01-2008, 18:02
Thexder Thexder is offline
Thexder will become famous soon enoughThexder will become famous soon enough
Team Update #2
Posted 11 January 2008: http://www.usfirst.org/community/frc...nt.aspx?id=450
What to say about it?
Section 10.2.8.1
The 2008 Trackballs require some care in assembly and inflation. Each Trackball consists of two parts: a Bladder and a Cover. The bladder has a 120cm diameter and is made of 2500g PVC.
Unread 11-01-2008, 18:15
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Team Update #2
Originally Posted by Thexder View Post
Section 10.2.8.1
Is this as much of a bombshell to everyone else as it is to me? Section 6.3 says the balls are approximately 40", and ours came up a couple inches short even with the help of the compressor. 120cm is more than 47"... I'd think this would make a HUGE difference for a lot of designs, both in terms of the size of your gripper, and how much this thing is going to bounce if you stretch it out 20% more. I'm hoping to see this re-clarified soon.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 11-01-2008, 18:18
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Team Update #2
I like that they clarified that disabled robots may be pushed out of the path of travel without penalty. This was a point of discussion on one of the threads here.
I dislike that they reused <G36>. The OLD <G36> was the height restriction on robots in the opponent's home stretch. Update 1 said <G36> has been removed. Update 2 says <G36> disabled robots may be pushed out of the way w/o penalty. I think that <G36> should have simply been gone, and the new rule should have gotten a new number, rather than reusing the number.
<G38> and <G40> regarding impeding a robot and "bumping to pass" are now only applicable during teleoperated mode. I think this is good, because I think no team would be attempting to implement a "bump to pass" during autonomous. It also opens up some potential defensive strategies which have been discussed elsewhere (i.e. blocking during the hybrid mode).
<G42> now applies the protection of a robot in the process of hurdling to both the robot and the trackball.
The inspection checklist has had "Robot Class" removed -- this was obviously just left in when copying from last year.
<T15> should make qualification matches go a little faster. During elimination matches, the higher seeded alliance can position their robots after the lower seeded alliance positions their robots; during qualification matches, alliances position their robots simultaneously.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 11-01-2008, 18:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Team Update #2
The source provided by FIRST for additional trackballs, www.sportogo.com, does not sell 120cm balls, only 102cm (40") balls. I think we just have a typo here.
Also, on that note, I don't see any balls with plain blue or red covers. They're all some sort of hyper-large sports ball and they're all really expensive.
--Madison--
...down at the Ozdust!
Unread 11-01-2008, 18:27
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Team Update #2
The shells are a special order for FIRST. The bladder can be purchased on its own through Sportogo for $20.50. If you want a second ball completely with shell and bladder, it will be a quite bit more.
-Michael Dessingue
Unread 11-01-2008, 18:30
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Re: Team Update #2
Is there a typo in the weight in Team Update #2, too? The update says that the bladder is supposed to be 2500g, whereas the one in your link is only 2200g.
_
Unread 11-01-2008, 18:33
Re: Team Update #2
I noticed that after i posted the link. I am going to try to verify that the bladder was not different than this one and repost when i can verify correctly.
-Michael Dessingue
Unread 11-01-2008, 18:54
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
Re: Team Update #2
Why can't FIRST provide a manufacturer and Part #? This would ensure that everyone gets the proper ball. I did notice last weekend that there was a 40" ball and a 120cm ball mentioned, perhaps you buy the 120cm and only fill it to 40" (i.e., just enough to fill the cover)?
Unread 11-01-2008, 19:10
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Team Update #2
FIRST already ensured that every team received the proper ball, by including one in the kit.
Richard Wallace
since 2003
Unread 11-01-2008, 19:23
SSMike's Avatar
SSMike SSMike is offline
The Guy with the Big Blue Two
FRC #0250 (The Dynamos)
Team Role: Operator
SSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond reputeSSMike has a reputation beyond repute
Re: Team Update #2
I personally like the new <G36> because it doesn't incur a penalty on a robot that has been disabled and cannot move. A penalty would just add insult to injury.
Long Live #4
Just when I find the key to success, someone goes and changes all the locks.
"It's kind of fun to do the impossible" -Walt Disney
When you put 'THE' and 'IRS' together, it forms 'THEIRS'. Coincidence? I think not!
Why is the name of the phobia for the fear of long words: hippopotomonstrosesquippedaliophobia?
"There's no such thing as a winnable war......." Bring our Troops Home
I will never let you fall
I'll stand up with you forever
I'll be there for you through it all
Even if saving you sends me to heaven
--The Red Jumpsuit Apparatus
Unread 11-01-2008, 19:26
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Re: Team Update #2
There is absolutely no way that the balls are 47". The cover that came with them would burst at the seams.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 11-01-2008, 19:30
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
Re: Team Update #2
But, doesn't that mean that if a team panics and forgets to push the E-Stop Button they get penalized
Unread 11-01-2008, 19:41
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Re: Team Update #2
If it is obvious that there is a problem to the refs, and your team is freaking out, the refs will most likely remind you about the E-stop if at all possible. It may come as a surprise, but refs really don't want to give penalties if they are preventable.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 11-01-2008, 19:46
Bharat Nain's Avatar
Re: Team Update #2
Robots can be disabled from the field also. I am sure if it is a safety hazard someone behind the table will pull the plug.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 11-01-2008, 19:52
SSMike's Avatar
Team Role: Operator
Re: Team Update #2
[/notsarcasm]Yeah refs are usually very good at reminding you of these things to prevent penalties.[not sarcasm]
I don't see them having to remind too many teams though. If you tip over and can't go back, the drivers should then know what to do.
Long Live #4
Team Update 16 (3/16) Joe Ross General Forum 2 17-03-2005 16:34
Team Update #9 Curtis Williams General Forum 10 03-02-2003 20:37
Team Update #7 Up Steven Carmain General Forum 5 27-01-2003 23:15
Team Update #3 is up pavelthegeek Rules/Strategy 8 24-01-2002 14:51
