Go to Post sigh, I started wondering why we weren't there than I realized it was in California. Thats a bit of a road trip... - Raumiester2010 [more]
Unread 11-01-2008, 18:07
Lafleur Lafleur is offline
AKA: Tom Lafleur
FRC #0812
Lafleur will become famous soon enoughLafleur will become famous soon enough
Re: New C18 3.0+ Compatible FRC Code
Kevin:
An idea...
A quick and dirty utilizations counter...
Add a global long integer to you project called "cycle". At the end of the while(TRUE) in main.c, do a cycle++ to build a loop counter, this will tell you how many time you have been in the while(TRUE) loop.
In the 26.4ms loop, read the cycle counter, clear it and divide by (264k clock cycles, the number of clock cycles in 26.4ms - the number of cycles used in the while(TRUE) ) This will give you a crude % utilization of the CPU that the teams can use to check on there code efficiency...
also, the counter could be scaled so that one could use an unsigned int
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
