Go to Post My own opinion is that any truly great student can succeed with any teacher, and any truly great teacher can succeed with any group of students. - DampRobot [more]
Unread 11-01-2008, 18:37
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
Arm help
Rookie Team Question:
We are building an arm, 60 tooth sprocket, driven by ?
What are the best choices for the motor?
Assume CIM's are not available.
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 11-01-2008, 18:47
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: Arm help
last year we used the window motor, and it worked, but it's realy roughed up now....
do you need finite control? if not, then i'd say use a piston.
Unread 11-01-2008, 18:56
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Arm help
I would suggest using the fisher price motors with these gearboxes on them. Our team personally has not used these on an arm but they are some of the powerfuller motors in the kit.
-vivek
"we don't build robots, we build people"
Unread 11-01-2008, 19:22
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: Arm help
-vivek
The AM planetary gearboxes do not provide a large enough reduction to drive an arm on their own. You would have to couple them to some other gearbox.
Unread 11-01-2008, 19:23
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
Re: Arm help
when you need power look at cims on a AM single speed or a van door
remember a piston has two positions it's really hard to any have more
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 11-01-2008, 19:59
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Re: Arm help
we would like to drive the 60 tooth sproket with something like a 10 tooth, perhaps the van door motor, but I suspect the worm gear might fail?
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 11-01-2008, 20:38
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Arm help
When I came up with an arm design for my team I used the Tiange van door motor running through a 2:1 reduction and it should have has more than enough power. One of the issues with the van door motor is that it has a worm gear which means that you can't put the arm down by hand it needs to be forced down. But also that is an avantage if you wanted to used a closed loop system because then your motor does not have to stall to lock in place. Good Luck
-Dustin Benedict
Unread 11-01-2008, 20:45
human
AKA: Colin Nobles
FRC #0148
Re: Arm help
yes he's right the van door can't be back driven this can be good and bad to make the motor more easier to back drive loosen the (2) set screws on the shaft that the worm gear is on, note you do not have to deassembled the gear box there on the outside
Unread 11-01-2008, 21:47
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Re: Arm help
If we run the van door motor to a 10 tooth to 60 tooth sprocket, it should take about 2.5 sec to raise up over the bar. Would this strain the worm gear or is it robust enough?
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 11-01-2008, 21:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Arm help
How long is this arm and how much weight is there on it (at the end, and the overall arm weight itself)? How fast and how far does it need to move?
this info might make a big difference in motor recommendations
Unread 11-01-2008, 22:12
Team2339's Avatar
Mentor#1
AKA: Myrle McLernon
Re: Arm help
Pivot to center of mass of the ball is aprox 48".Arm weight about 10#, speed can be compromised for placing the ball over the bar.
A hurdle can be pushed, the end game requires it to be somewhat set in place.
We have already allowed for slower movement and durability, since this is our first year and we want to make it through 10 matches functioning.
I wasn't able to find any engineering specs for this van motor, the one 2 years ago would have worked.
How stout are the worm gears?
2008 LA Regional
2011 Bound for same
KQ6Y
Unread 11-01-2008, 22:16
vivek16's Avatar
AKA: vivek
Re: Arm help
just make sure you have a low enough center of gravity and don't tip when trying to do this.
-vivek
Arm and Lifts Powerpoint help Bob Steele Technical Discussion 10 09-11-2007 13:24
PLEASE HELP!! Need help programming arm?? amirjpl Programming 12 15-03-2007 15:11
Manipulator(Arm) Help Agent Gruer Technical Discussion 16 01-02-2007 11:44
I Need Help With An Arm Team ICE #1611 General Forum 4 20-01-2005 14:37
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
