Go to Post When's the last time you called up FIRST headquarters just to say thanks? Or saw a volunteer at a regional and said, 'Hey, you're doing a really great job here. Thank you for everything you're doing in your spare time.' - Amanda Morrison [more]
View Poll Results: Should the maximum robot dimensions be...
Increased? 7 9.46%
Decreased? 12 16.22%
Unchanged? 55 74.32%
Voters: 74. You may not vote on this poll
Unread 03-09-2001, 23:01
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
I think making the limits smaller will tend to hinder rookie teams because they have not yet learned to complete all of the tasks using a smaller amount of space. Also depending on the task, like lifting a big ball, even the most veteran of teams would have trouble with a smaller robot. Just look at how accurate most teams were with the big ball this year. Now if the tasks were lower or smaller I could understand making the robots smaller. But all in all the size is not out of hand, the robots are still managable and the larger size allows for more variaiton in the robots. besides there is no rule that says your robot can't be as small as you want it to be, so more power to the people that make thier robots small and maneuverable.
Unread 05-09-2001, 11:04
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I am going to attempt to end this in 3 very true words:
BIGGER IS BETTER
Unread 05-09-2001, 13:26
Carolyn Duncan Carolyn Duncan is offline
The_C
Carolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the roughCarolyn Duncan is a jewel in the rough
Bigger is not always better...
The size of the robots should be based on the game. Sometimes things get too big to handle safely. Things tend to get cumbersome when they are larger. Weight is not always balanced as well and the cg changes. I'm not saying that the robots should be smaller or larger, but that the size constraints should be set to the game. I also think that access to the field will have to be made better than it was last year.
C~ya,
Carolyn Danielle
Thats C like the letter not like looking through your eyes or the large bdy of water! Just the letter C and yes it's on my birth certificate!
Unread 09-09-2001, 14:57
Tha access should be like battlebots- a ramp
Unread 13-09-2001, 15:44
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Carts
Actually, building a cart is not all that difficult. Our team's cart is rather simple, but has managed to hold three different robots with no problems. All it is is 4 pieces of angled steel with casters on the bottom and a piece of plywood across the center and a long handle on one side. Simple, easy, and efficient. Plus, the plywood makes it easy to decorate, or, can be removed if you space the sides out right.
Jeff
Unread 13-09-2001, 16:06
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Re: Carts
Jeff
I couldn't have described 639's cart better myself... Nice design
Unread 13-09-2001, 17:15
Re: Carts
Jeff
Did you build yours the day in school before you left for compitition too?
That design is great, you have no idea the abuse my team put that design through.
Greg
Unread 14-09-2001, 14:54
El Jefe de 148
No, we didn't, but it was not a high priority. A cart should be a functional transport vehicle, not a wacko crazy designed thing. (Though I must admit, T3's cart is really cool...)
Unread 14-09-2001, 16:25
Andy A. Andy A. is offline
Getting old
FRC #0095
Thumbs up
95 decided we wanted something a bit more flashy and functional in our cart (or war wagon as its called here). It was quickly decided it had to be powered.
Over the fall a wood from was built (complete with a really neato lift to allow easy acceses to the underside of the bot and drive motors) along with boxes for tools. By the time that was finished, the season started and we had to put it on the back burner.
After we shipped the bot, work resumed on the wagon. A pallet jack set up was used for the wheels (two fixed wheels and one center mounted wheel in the back that pivots to change direction). The drive motors were two old vandoor motors hooked up to a unused control system and old battery. A single joystick was the only control (tank steering on the the two powered wheels). Even had a nice suspension. Not only was it strong enough to move the bot and tools around, but a driver could stand on a fold out metal plate in the back and ride it around.
When we got to NJ, we found out that it bearly fit through the gym doors, and was to fast to ride in the pit. So we just walked behind it while controling it.
Unfourtantly, we had to take the controler out of it for use in an older bot (for demos and such) after nats , so its just collecting dust for the time being. For the summer games, we just used our practice strecher.
At least it was fun making the thing (riding it was even better!)....
-Andy
Whats your honest opinion? Sean General Forum 50 17-04-2003 21:05
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
What about prettiest robots? archiver 2000 8 23-06-2002 23:09
'Accidently' ripping other robots apart Vipersna Rumor Mill 6 04-01-2002 23:27
