Re: Best 80/20 linear bearings
Depending on your exact design you could rely entirely on the 80/20 as the slider itself. Team 612 did this last year and it worked perfectly, never jammed, never failed and it was smooth all the way up and down.
All you have to do is take the corner of one piece of extrusion and slip it down the other piece, and then you have a slider. But if you have some sort of carriage at the end that is not made of 80/20 you probably do need linear bearings, and I may be mistaken but 80/20 suppliers often carry them. Here is a picture of our elevator http://www.chantillyrobotics.com/pho...g2_itemId=3924 |
We have used the 80/20 Single UniBearings for several years now with great success. The specific part number to mate with the 1010 extrusion is 6760. However, we have made two significant changes to them:
1) We always loctite the #8-32 flat head screws, as they tend to come loose over time. (as they are practically impossible to service once built) 2) We always replace those same flat head screws with longer screws. The supplied 1/4" long (IIRC) flat head only catches 2 or 3 threads. We go to a longer 5/16" screw to ensure the proper engagement. Please let me know if you have any further questions. Bengineer |
| Linear slides | Andrew Schuetze | Kit & Additional Hardware | 10 | 18-01-2008 23:37 |
| 80/20 linear motion? | Nitroxextreme | Technical Discussion | 15 | 22-01-2007 09:55 |
| Linear Potentiometer | FRC1710 | Motors | 4 | 15-01-2007 19:20 |
| Linear Actuator | NoRemorse | General Forum | 4 | 17-01-2004 21:02 |
| Linear slides | Gui Cavalcanti | Technical Discussion | 4 | 02-01-2004 15:59 |
