Go to Post Design is iterative, right? - JesseK [more]
Unread 11-01-2008, 16:30
1594code 1594code is offline
FRC #1594
1594code is an unknown quantity at this point
How do you wire the gear tooth sensor?
Hi,
Our team hasn't used sensors other than the CMU camera and limit switches before. We have an idea how to program the gear tooth sensor, but how do you wire it? PWM cables seem to fit well, and I see that they are what the manual recommends. How do you fasten the PWM cable into place on the sensor board? Soder?
Where on the RC or robot do you connect the PWM cable that supplies the 12Vdc operating voltage?
And the +5 cable connects to a Digital Input port on the RC, no?
Any advice would be appreciated!
Unread 11-01-2008, 18:42
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Re: How do you wire the gear tooth sensor?
I found this when I was looking: http://www2.usfirst.org/2007comp/oth...r%20Manual.pdf
Unread 11-01-2008, 19:37
mneary mneary is offline
FRC #1759
mneary is an unknown quantity at this point
Send a message via AIM to mneary
You might consider using the 2008 manual instead (although at a glance they appear to be the same).
http://www.usfirst.org/uploadedFiles...sor_Manual.pdf
Unread 11-01-2008, 21:43
FRC #1594
Thank you for the links. I am still wondering: How do you fasten the PWM cable into place on the sensor board? Soder?
Unread 11-01-2008, 21:46
Branden Ghena's Avatar
Branden Ghena Branden Ghena is online now
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
I used a terminal block to attach the wires. I thought it would be WAY too difficult to attach the tiny wires of the IR sensor to the bigger power and ground wires, and it allowed me to attach the pwms pretty easily, although I did need to to cut one end off of them.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 12-01-2008, 16:24
FRC #1594
Thank you for your reply! So... do we wire the PWM cable connected to the 12V holes on the Gear Tooth Sensor to a terminal strip on our electronics board? Our PWM cables seem to be male/female-- don't we need male/male for that? Should we cut and trim the PWM cable?
We don't have an experienced electronics team-- it would help if someone out there could spell it out...
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor Nathan Programming 4 12-01-2008 15:09
How to integrate Gear Tooth Sensor magical hands Programming 0 18-02-2007 17:43
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Mounting the Gear Tooth Sensor??? blue_crew Electrical 3 09-02-2006 13:53
