Go to Post Don't worry about someone stealing your ideas...if they're good ideas, then imitation is the sincerest form of flattery. If they're lousy ideas, we'll let you know, so you can work on finding a better idea. win-win! - MrForbes [more]
Unread 06-01-2008, 16:48
nzamorski nzamorski is offline
AKA: Nick Zamorski
FRC #2062 (C.O.R.E. Community of Robotic Engineers)
nzamorski is on a distinguished road
The Field
My team is looking at building the overpass of the field. We know that the outside rails are made of pvc, but I don't know that the inside of the rails are. Does anyone know what the inside pipe is or what did your team use to build the overpass? Thanks for the help.
C.O.R.E. Team 2062
Waukesha, WI
Visit Our Team Website
www.core2062.com
Unread 06-01-2008, 16:52
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Re: The Field
If you go to the arena manual, it describes all aspects of the field. I believe it also has instructions on how to build it. There is also a link on how to build a low cost version of the field, however I have not looked at it so I dont know if it will help or not.
Joey
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 06-01-2008, 17:22
David's Avatar
David David is offline
FRC #1647 (Iron Devils)
David is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the roughDavid is a jewel in the rough
Send a message via AIM to David
Re: The Field
[QUOT]6.2.2 The OVERPASS
The OVERPASS structure extends acoss the minor axis of the TRACK. The OVERPASS is constructed of 1-1/2 inch O.D. steel pipe and connecting hardware.[/quote]
So the official specs call for the overpass to be made of entirely steel pipe, however the team setup calls for 1in Iron pipe encased in 1-1/4in pvc pipe drawings, assembly instructions and a BOM can be found at http://www.usfirst.org/community/frc...t.aspx?id=7682
These are the individual documents.
http://www2.usfirst.org/2008comp/Dra...E/2008_TFE.pdf
http://www2.usfirst.org/2008comp/Dra...ly%20Guide.pdf
http://www2.usfirst.org/2008comp/Dra...ev4_010308.xls
Unread 06-01-2008, 17:26
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: The Field
We're going to see if we can make one (practice/prototyping) half overpass using some 1" EMT I have laying around. Should be interesting....
edit: here's the plan, I hope you can read it! I can't
Unread 06-01-2008, 20:32
Miniflash's Avatar
Miniflash Miniflash is offline
AKA: Gordon Wyant
FRC #2028 (Deep Impact)
Team Role: Human Player
Miniflash is on a distinguished road
Re: The Field
they had a mock feild at VCU made completly out of PVC and plywood
Unread 06-01-2008, 22:25
MrForbes's Avatar
AKA: Jim
Re: The Field
It's all done except the splice in the center...which will be some light steel angle screwed on either side of the tubing, at the joint with self drilling sheet metal screws.
This is the Unofficial Larry Henson/Randy Wilson Memorial FIRST Overdrive Practice Overpass.
(Larry and Randy were friends of mine who passed away recently....they gave me the conduit)
Unread 06-01-2008, 22:29
MikeCarlovsky's Avatar
MikeCarlovsky MikeCarlovsky is offline
POPO's - PAPA
FRC #1625 (Winnovation)
MikeCarlovsky is an unknown quantity at this point
Re: The Field
PVC alone we think would be to weak to hold two of the TRACKBALLS.
We are making ours with steel pipe insterts in the PVC for stability.
Unread 07-01-2008, 00:01
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Re: The Field
Not quite completly PVC and plywood. The uprights had steel inside the pvc, or on the sides, just steel uprights. The monkey bars also had steel inside in the center.
Also included were a TON of zipties. This field is going to use more zipties than any field I can remember.
Wetzel
Viva Olancho!
Unread 11-01-2008, 22:06
Miniflash's Avatar
AKA: Gordon Wyant
Re: The Field
ah i geusse you were right, it did have some metal peices.. my bad lol
Unread 11-01-2008, 22:20
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
Re: The Field
675 has constructed a practice field that is roughly half of the field with one overpass which came out very nice, it has already allowed our programming robot nice traction.
It really is a good idea
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 12-01-2008, 01:09
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: The Field
1625 constructed the entire center piece of the field
-2 overpasses
-center dividing walls
-end bevels at the 4 corners of the field
-back wall (the wall of our shop)
so we have a pretty good replica of the official field to practice on...
We hope to have the 07' bot working soon so we can test the field out
Building the field :: where can I get the carpet? Armando Gonzalez Technical Discussion 10 12-01-2007 14:14
pic: Overview of field at the Vex scrimmage at the Duel Carol Extra Discussion 1 24-10-2006 16:37
What is the field of view (FOV) of the default lens? Jared Russell Programming 7 26-01-2006 21:54
the 50 point not touching the field rule slavik Rules/Strategy 15 11-01-2004 22:00
So does anyone know what the name of the new field archiver 2001 4 24-06-2002 03:01
