Go to Post However, do not confuse faith in your ability to overcome challenging obstacles, with the difficulty of the obstacles themselves. - Joe G. [more]
Unread 11-01-2008, 23:20
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Re: SetPWM and our IR controls
I would check that the wheels are actually hooked up to pwms 1 and 2 (don't laugh I've done this), and whether the code is actually running, i.e. the the robot is in operator mode and is enabled.
You could also try a simpler loop
void OperatorControl (void )
while(1)
printf("hello");
If you hook your computer up to the robot, and leave it attached when you run it, this should show something (make sure the terminal window isn't in GD mode)
Yes, the data processing function is the operator control mode where you put this code, and it is called automatically from Main(); so you should be good.
P.S. Also, I program in EasyC and have never had any problems with infinite loops for testing purposes.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Last edited by Branden Ghena : 11-01-2008 at 23:24. Reason: I needed to add some info
help us program our controls dude_brd Programming 1 10-02-2007 12:02
need help on programing our controls dude_brd Programming 1 07-02-2007 18:42
FRC: Reset and Program Controls yanksrock777 General Forum 4 24-01-2007 22:37
Push Button and Switch Suppliers for OI controls Goldberg204 Control System 8 11-01-2007 15:27
pic: 383`s controls and driver Manoel Robot Showcase 13 03-03-2005 00:57
