Go to Post Changing the world starts with changing yourself. - Jeremy_Mc [more]
Unread 12-01-2008, 02:40
AKA: Dr. Brooks
no team (WRRF)
Re: Gyroscope saturation?
Your friend, if the amplitude is large enough, because it helps you with the quantization error, making the higher sampling rate useful by producing an average. If really old white papers are still laying around on CD, I believe that there is a white paper on the topic.
Eugene
Originally Posted by sumadin View Post
My friend because it makes such measuring rates unuseful, and therefore helps keep the processor under a lower load than if they were? Or for another reason I'm currently missing?
Has it even bee / is there a good way to quantify ADC conversion noise? So that I might be able to know what's the minimum useful sampling rate?
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyroscope ADXRS300 of Analog Devices rebekka Technical Discussion 2 07-12-2006 12:36
Stick Saturation Ralph Lambert Technical Discussion 7 20-01-2003 09:24
Gyroscope Orentation Decay D.Viddy Programming 12 13-01-2003 14:43
