Go to Post In an education culture that hinges on having the perfect grades and perfect SAT scores to get into the perfect colleges, I enjoy providing an environment where students are encouraged to test their own hypothesis, challenge their assumptions, and regularly fail. - Michael Corsetto [more]
Unread 12-01-2008, 04:33
Racer26 Racer26 is offline
Re: Confused about air usage
Originally Posted by calvin1631 View Post
I am confused about air usage. we were setting up a prototype pneumatic system using a 3/4" x 10" cylinder, and 4 tanks. We pumped up the tanks to 100psi and had the pressure limited to about 35psi to the cylinder. I only got it to go in and out about 9 usable times. I saw a formula to calculate this related problem and found that we should technically be able to at 120psi, with a 3/4" x 10" cylinder, have 20 actions. What am I doing wrong?
I believe your calculations are shown by your experience. The 20 "actions" you calculated theoretically transfers to the actual 18 you got, 9 ins and 9 outs, if I'm understanding you correctly.
Confused about Atlanta Rick-906 Championship Event 6 21-03-2007 18:19
Confused about potentiometer values Kirk Technical Discussion 4 11-03-2006 16:29
Confused about Interrupts karch Programming 11 31-01-2005 09:51
Confused about Camera AnkurG Programming 5 26-01-2005 19:50
Confused about chat.... Elgin Clock CD Forum Support 5 15-11-2001 07:58
