Go to Post Just that the robot battery wont catch fire if you drop it the wrong way. Those LiPos pack quite a punch. - dellagd [more]
Unread 12-01-2008, 03:12
Tack610's Avatar
Tack610 Tack610 is offline
FRC #2413
Tack610 is an unknown quantity at this point
2008 rookie needing help.
Ok this is my first post so i must be doing something right. Right now we're working on wheels for our robot. We used the kitbot chassis and everything (you know cause we're rookies), but the wheels are stumping me. I have the gearbox's and motors attached, but I don't know how to:
A) attach the wheels to the gearbox/motor assembly, and
B) how attach all of that to the robot.
We're thinking of using the Chains but i dont know how to really connect anything. So in advance thanks from team 2413.
Unread 12-01-2008, 06:41
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Re: 2008 rookie needing help.
That's a tough question to answer without knowing more facts but:
most people use chains.
If you do use chains consider chain slippage and that you may have to use some type of chain tensioner.
The configuration depends on how many wheels and if it is front/rear/center wheel drive.
Make sure that all motors and chain sprockets are lined up to each other.
I would suggest that you do search of robot drawings from past competitions that can be found here or on the AutoCad web page called Firstbase
Good Luck and welcome aboard
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 12-01-2008, 08:01
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Tack,
You are in the same position we were in last year. We we got the KOP in 2007 i thought everything i needed to make the robot "run" were in the two totes we picked up. I was sadly mistaken. The first thing i noticed was that there weren't axles in the kit, i think they fixed that this year with the 1/2" aluminum shaft in the kit this year. You can do several things to attach the wheels to the frame. Drill out holes to 1/2" and slide the axles through the holes. What we did was drill out the holes to 5/8" and use a flange bearing in each hole (see pics below). Using a chain to drive the wheels is a great idea. You will need to buy a "chain break" to get the chain to the length you need. You can get one at Lowe's for ~$22.00. While you are at Lowe's get a few "master links" so you can make a loop of chain for your drive.
Here is what we did last year:
http://www.chiefdelphi.com/media/photos/27588
http://www.chiefdelphi.com/media/photos/27587
It's a 6-WD with two different chains on each side. This is not needed to get the 'bot running. As long as you can get power to at least one wheel on each side, you can get moving. You will be surprised at how awesome seeing your first robot move under its own power feels. We were cheering in the hallways the say ours moved for the first time.
Unread 12-01-2008, 08:35
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
You can use a angle grinder as a substitute for a chain break.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 12-01-2008, 15:02
Sunshine's Avatar
Mr. S
FRC #2062 (C.O.R.E)
No,
You do not break the chain, you remove the pin to take a link out.
needing help choosing.. 3dude_2231 College & University Education 3 01-04-2007 13:11
Rookie Team's Needing Help!!! nyu500 General Forum 3 23-01-2007 17:14
poor little newbish programmer needing help Oumonkey Programming 13 14-07-2005 21:47
Rookie help doyler Technical Discussion 55 11-01-2005 08:59
help to rookie teams archiver 2001 5 23-06-2002 23:38
