Go to Post Quoting Fred Durst--"Bring it on." - Billfred [more]
Unread 12-01-2008, 10:51
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: Using the USB Chicklet with a steering wheel
Ok, we're thinking about steering wheels also. Just making sure that pedals on the floor are legal, even if we stand up. Otherwise someone will have to control it on the shelf.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 12-01-2008, 11:58
The Lucas's Avatar
CaMOElot, it is a silly place
Please read this Q&A response
Basically The Driver has to hold the Pedals during Hybrid
Robot Inspector
Unread 12-01-2008, 21:22
synth3tk's Avatar
AKA: David Thomas
Thanks for the clarification!
Unread 12-01-2008, 22:11
daneelshof's Avatar
daneelshof daneelshof is offline
Programming Mentor
FRC #1619 (Up-A-Creek Robotics)
daneelshof has a spectacular aura aboutdaneelshof has a spectacular aura about
I can tell you from experience that the Logitech Nascar Steering Wheel works well with the robots, however it was a lot of work and basically had to focus on it for the entire build season. Here are some things to think about:
1. With skid steering (either 4-6 Wheels or tank treads) the zero-turn radius of the robot will not be as intuitive as two joysticks.
2. The steering wheel is much more accurate, linear, and stable with regards to PWM signals to the controller than any joystick I have tried.
3. There are two pedals to work with (possible reverse accelerator).
4. There are shift paddles and several other buttons on the wheel, however you must figure out bit masks to use many of these buttons because they are passed to the controller through the unused y axis.
Don't be afraid of standing while using the pedals on the floor, and remember to give your drivers time to practise and take their feedback to improve the system. Oh, and make sure to thoroughly read and understand the chicklet documentation.
Regards, Dane Elshof (Mentor Team 1619)
Unread 12-01-2008, 22:26
synth3tk's Avatar
AKA: David Thomas
Thanks. We are making a pretty customized OI this year, including the steering wheel/pedals. Looking forward to seeing how it turns out.
Unread 13-01-2008, 11:43
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
As of now, The USB Chicklet only supports the NASCAR racing wheel. It is my understanding that that device is no longer in production. When developing the Chicklet we wanted to support a variety of control devices. Ironically we picked the NASCAR racing wheel because of it's availability. We do write custom drivers if there is a particular device a team would like supported. There is a charge for this service. It is $25, per device, per Chicklet and $10 for any additional Chicklets. The device must be of the HID class.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Comments on the Logitech steering wheel with pedals waialua359 Control System 7 14-12-2007 16:08
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
Does EasyC Pro work with the USB-Chicklet? lightning_blast Programming 6 20-01-2007 23:39
Using the IFI loader with a USB-to-serial adapter? Eldarion Programming 7 26-01-2006 23:33
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
