Go to Post Is it really that bad to ask a team to be able to do more than just drive? It's like asking a student to do more than just show up to class... - Katie_UPS [more]
Unread 12-01-2008, 11:33
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Re: MPLAB workspace (HELP!)
Yeah, I had that problem recently too. I just copied and pasted my .c file text and saved it as a .asm file. The compiler reads this and tries to build it. My problem is that it shows 94 (!) errors, even though I'm using a C source code! (If you're using the 2007 source code then the same will happen to you too.)
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 12-01-2008, 11:42
Sean Marks's Avatar
Sean Marks Sean Marks is offline
AutoCAD User
AKA: Sean Marks
FRC #2016 (Mu Mu Psi)
Team Role: Student
Sean Marks is a jewel in the roughSean Marks is a jewel in the roughSean Marks is a jewel in the rough
Send a message via AIM to Sean Marks
yea, I am of course using 2007 code. As far as I know there is no 2008 code.(yet at least)
I'm gonna try redownloading the code. Start from scratch, and add the .c files individully.
2008-NJ Semi-Finalist (Thanks 694 & 1279) / Chesapeake Winners (Thanks 1418 & 11) / Newton Finalists (Thanks 1574 & 141)
2007-NJ Rookie All-Star / Monty Madness Champs
Unread 12-01-2008, 11:54
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
Well, we decided to just try using the workspace/projecc that comes with the default code, but when compiling that the build fails with:
error - Coff file format for 'ifi_library.o' is out of date
error - Coud not find member 'ifi_library.o' in library file 'C:\filepathToProject\FRC_library_8722.lib'
I'm not sure what else can be done to setup a working project space...
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Once you have created the new project using "New" you need to choose the ToolSuite to use.
Menu "Project:Select Language Toolsuite...", brings up a dialog.
Menu "Active Toolsuite:" choose "Microchip C18 Toolsuite".
All the C files should now be in the "Source Files" list.
You may also need to set the locations of the various tools if you have a non-standard setup (might be easier to reinstall a standard setup if you don't know what you are doing).
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
Unread 12-01-2008, 12:00
Sean Marks's Avatar
AutoCAD User
AKA: Sean Marks
Team Role: Student
I did what you said AndrewN and it eliminated some of the errors, but I have the same problem as bronxbomber92, it says that my ifi_library.o is out of date.
Unread 12-01-2008, 12:32
If worst comes to worst, would someone mind uploading a working project with the default code for MPLAB 3.0?
Help on MPlab Devo1098 Programming 13 25-02-2007 02:28
MPLAB 7.20 Help please? groovy69 Programming 14 22-01-2007 02:00
Help with MPLAB burningpig Programming 9 17-01-2007 13:10
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
Need Mplab help ASAP !! L33T-meh- Programming 3 03-02-2004 21:39
