Go to Post "prepare to take flight"! I see people taking off shoes and waiting in long lines. - 346CADmen [more]
Unread 11-01-2008, 09:12
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
Using the IR
Does anyone have a link to a manual with information about how to use the IR board, how to get started with it ?
The link on the manual that came with the IR board doesn't work anymore and my team desperately needs help getting started.
Visit team 2217 channel:
http://www.youtube.com/profile?user=team2217
2007 Israel Regional GM/Technion Rookie All Stars
Participated in 2007 Atlanta World Championships (Newton Division)
______________________________________________
Visit team 2669 channel at:
http://www.youtube.com/user/team2669
Unread 11-01-2008, 10:02
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
Re: Using the IR
Sure, here you go:
http://johnmchilton.com/FIRSTIR.pdf
What place are we at? ... TODAI!
Unread 12-01-2008, 11:51
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Using the IR
I have some problems with it as well. We printed out the link above and we still cant figure it out. How do we hook it up to a battery? I assume that where it says pin # is the order of the wires. Like the brown is pin 1, red #2, ect, to black #10.
And why are there 2 wires for positive voltage and 2 for negitave?
Thanks,
Brandon
Team 2495
Unread 12-01-2008, 18:04
JohnC's Avatar
Re: Using the IR
Thanks,
Brandon
Team 2495
http://johnmchilton.com/IRBoard.jpg
There's a pic. Sorry some of the wire colors aren't exactly as they should be, but it's close enough to distinguish. The PWM cables go off to the RC, and the others go to our power distro.
Look closely at the board and notice that there are numbers printed near the ribbon cable pins. Here is a pinout of that:
1 12v Brown
2 12v Red
3 Gnd Orange
4 Gnd Yellow
5 Out2 Green
6 Out1 Blue
7 Out3 Purple
8 Out0 Gray
Unread 14-01-2008, 17:18
AKA: Brandon Liatys
Re: Using the IR
Thanks, but...where did you get that plastic thing?
Unread 14-01-2008, 18:33
Re: Using the IR
Two came in the Kit this year.
Unread 14-01-2008, 23:18
JohnC's Avatar
Re: Using the IR
Also, you don't HAVE to use that part. It was just there (two actually, and I think new this year), and I'm a fan of terminal blocks, so I used it
Unread 15-01-2008, 07:20
AKA: Brandon Liatys
Re: Using the IR
Did it come in the Igus bag? We didn't get that bag yet ;_;
EDIT: nvm
Unread 15-01-2008, 17:25
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Re: Using the IR
1 12v Brown
2 12v Red
3 Gnd Orange
4 Gnd Yellow
5 Out2 Green
6 Out1 Blue
7 Out3 Purple
8 Out0 Gray
i see on your image that the black (GND) wires in the PWM cables are running to something, am i correct in saying they are running to the negative on the din rail power distro block?
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 15-01-2008, 18:24
JohnC's Avatar
Re: Using the IR
Not the din rails, just a power distribution block's ground.
I'm a programmer so I'm no expert on electronics. Also...if you notice, the whole "stationary dev/test bot" thing is built on OSB lol.
Unread 16-01-2008, 17:23
drewjones13's Avatar
drewjones13 drewjones13 is offline
drewjones13 is an unknown quantity at this point
Re: Using the IR
1 12v Brown
2 12v Red
3 Gnd Orange
4 Gnd Yellow
5 Out2 Green
6 Out1 Blue
7 Out3 Purple
8 Out0 Gray
Do you guys run your positives and negatives through a breaker or straight to the power distrabution block?
Unread 16-01-2008, 20:38
JohnC's Avatar
Re: Using the IR
We aren't using the Rockwell block yet, but yes the positives are thru 20 amp fuses. The ground is just a common ground.
Unread 23-01-2008, 07:29
fernandoabel01 fernandoabel01 is offline
FRC #1382
fernandoabel01 is an unknown quantity at this point
Re: Using the IR
Hello,
Please....I want know, where I connect the board´s wire in my RC?
Unread 23-01-2008, 08:12
Re: Using the IR
Originally Posted by fernandoabel01 View Post
Hello,
The four output pins each connect to the signal pin of a digital input on the RC.
Unread 06-02-2008, 21:16
naruto137 naruto137 is offline
FRC #1656
naruto137 is infamous around these partsnaruto137 is infamous around these parts
Re: Using the IR
Ok, theres one thing im not sure about, do I connect just 1 wire from the digital output to the pwm or do I need to ground the black wire of that pwm to the ground of the power supply of the IR as well?
Using the IR Receiver on the Robot LG67 Control System 1 06-01-2008 01:42
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
Rules for hanging, using a loop over the end of the bar caffel Rules/Strategy 10 04-06-2004 15:04
Is Anyone Using Motors to Hoist themselves off the platform on the bar? xxlshortys Motors 36 25-02-2004 01:06
