Go to Post If regolith ever makes a return, I will jump out of a window. - Oblarg [more]
Unread 12-01-2008, 12:45
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
pic: FRC 1726 Steering Prototype
Unread 12-01-2008, 12:51
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: pic: FRC 1726 Steering Prototype
Did you get go-kart turning spindles and modify them? They look pretty good.
Unread 12-01-2008, 12:53
MrForbes's Avatar
AKA: Jim
No, we made our own, from some 1/2" bolts, square tubing, and flat stock.
Not much to it, really. We spent about an hour or so.
Anyone want to guess the weight?
Unread 12-01-2008, 13:07
AdamHeard's Avatar
Lead Mentor
So, the wheel rides on that bold, and the whole assembly is rotated on that hole in the tubing via that "arm"?
Unread 12-01-2008, 13:10
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Yes.
Unread 12-01-2008, 13:11
MrForbes's Avatar
AKA: Jim
You can almost see them in this picture, where I'm explaning the geometry to some of the new students.
http://photos.project1726.org/displa...lbum=25&pos=15
Unread 12-01-2008, 13:43
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
My team wants to use Ackerman steering, but they also want four-wheel drive. What would you recommend? please?
Unread 12-01-2008, 13:48
MrForbes's Avatar
AKA: Jim
I would recommend that you put two wheels next to each other on the rear of the robot on each side, in the fashion of a school bus (dualies), and then you'll have a 6 wheel robot with 4 wheel drive and easy to build Ackermann steering.
We plan on trying to set up the steering so the robot can turn very sharply, sort of like a forklift (but with front/rear reversed from a forklift), and making it turn that sharply pretty much rules out having shaft drive to the center of the front wheels like normal 4x4 trucks use. Instead, you want to make it work like a "crab drive" or "swerve" robot, and then it would not really make sense to bother with the Ackermann geometry.
also with a 2wd Ackermann system with very tight steering angles, it might be very helpful to have a programmed "differential" that drives the motors opposite directions to make the robot spin about the rear wheel center axis. We haven't figured this out yet, though.
Unread 12-01-2008, 14:08
AKA: artqny
haha that's a clever solution. Unfortunately, it didn't fly with anyone. Thanks though.
Unread 12-01-2008, 20:30
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
that looks like the steering knuckle on my go-cart that broke and made me crash
Unread 12-01-2008, 20:39
run the trap!!!
Team Role: Human Player
I don't want to sound overly harsh.... But what if any is the benefit of car steering?
I mean, you realize that this game isn't really as simple as "Go straight and turn left" it will take a great deal of maneuvering to pick up and hurdle a track ball (which I assume you are trying to do).
Just imagine trying to make a five-point turn every time you want to pick up your ball
I don't think this game will really resemble a race, I think it will look more like a game of "territories" with robot progressing through the "territories" in a counterclockwise direction.
-Philip J. Fry
Unread 12-01-2008, 20:59
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Looks Great NERDS! Keep it up! Looking forward to alliancing with you all!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 12-01-2008, 21:07
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
2075 is going for the ackerman system, even though I don't agree with it.
I think we are over thinking it. Were hoping to an engineering award with the rest of our drivetrain though.
MrForbes's Avatar
AKA: Jim
Originally Posted by Hachiban VIII View Post
It will take a great deal of maneuvering to pick up and hurdle a track ball (which I assume you are trying to do).
We are well aware of the difference in close maneuvering with the car type steering, and have a back up plan to build the drivetrain as 6wd if we feel it won't perform well enough.
At the same time, we are working hard to make it easy to pick up and hurdle the ball, and hopefully to catch it on the bounce. And if the ball stuff doesn't work as planned, we will have a fast lapper
That is quite possible. Predicting how the game will play out is a risky business!
(and thanks for the encouragement Fredi, should be fun having you at both regionals this year!)
Unread 12-01-2008, 21:14
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
For the sake of knowing, in what way did it break?
pic: 1726 Promobot GUI Extra Discussion 18 01-11-2007 18:04
pic: FRC 1726 Vex camp competition yodameister Extra Discussion 1 10-07-2007 21:41
pic: FRC 1726 Vex camp emcee yodameister Extra Discussion 1 23-06-2007 01:26
pic: FRC 1726 suspension MrForbes Extra Discussion 4 22-12-2006 15:57
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
