Go to Post rebound rumble didn't really have a lot of rebounding or surprise earthquakes. - Rynocorn [more]
Unread 09-01-2008, 19:50
EricH EricH is online now
Re: Hybrid mode?
Originally Posted by Justin M. View Post
To my understanding, yes, that is legal. You are allowed to communicate no more than 4 actions to the robot. I don't see why you can have 3 done by one channel, but that only leaves you with one action left.
You should make each channel do one task to make things easier, but if you technically have no more than 4 tasks done by the same channel, that appears to be legal.
If you go by the "Mars rover" analogy, you have three left. As long as you say what the actions or sequences thereof are, you have no problem.
Now, you could make a case both ways. Or you could ask Q&A if one "action" can be a series of actions triggered by one command sent by one button push or whatever you use.
Unread 09-01-2008, 20:35
Re: Hybrid mode?
Originally Posted by Elgin Clock View Post
What are some other forms of remote communication (AKA: Signaling device) we are allowed by the rules to use this year other than IR types?
The rules are quite helpful on this topic.
Originally Posted by <R65>
...Active SIGNALING DEVICES shall:
• use visible light, infrared communications, or sound as the transmission method – no other form of electro-magnetic radiation is permitted
All three of those methods were demonstrated during the kickoff.
Unread 12-01-2008, 14:24
tails9889's Avatar
tails9889 tails9889 is offline
FRC #1006
tails9889 is an unknown quantity at this point
Post Re: Hybrid mode...
umm... in hybrid mode the robot is controlled by the robocoach... so can the robocoach signal the robot to go clockwise in hybrid mode
Unread 20-01-2008, 17:35
Hydra's Avatar
Hydra Hydra is offline
FRC #0909 (Junkyard Crew)
Hydra is an unknown quantity at this point
Re: Hybrid mode?
So does anyone know what frequency of the remote we will be using? And what about the code for programming?
Unread 20-01-2008, 22:50
Re: Hybrid mode?
Pick your own remote. Write your own code. Ask for help if you need it.
Unread 21-01-2008, 07:11
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Hybrid mode...
As long as the robocoach doesn't mind suffering the wrath of the alliance partners when the 10-point penalties start accumulating.
(since 2004)
Hybrid mode issue Los Frijoles General Forum 2 07-01-2008 18:52
Track balls off the overpass in Hybrid mode- who scores? Japper Rules/Strategy 1 07-01-2008 11:24
Has a hybrid won yet? chaoticprout General Forum 46 27-04-2007 22:44
pic: VEX hybrid John Gutmann Extra Discussion 3 01-02-2007 12:08
Safari Hybrid View Problems Joe Matt CD Forum Support 4 09-12-2003 00:19
