Go to Post Welcome to the imperfect world of design! - Joe Johnson [more]
Unread 12-01-2008, 13:50
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Help with Inventor Files of Toughbox Mounting
I have been unable to find any technical drawings or cad files of the new mounting system for the toughbox gearboxes.
If anyone has dimensions of either of the 2 pieces please help me out.
The only thing i have to go from right now is this picture:
Unfortunately the parts are locked up for the weekend and i can't measure them, any help is appreciated
Thanks,
-Adam Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 12-01-2008, 14:25
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
Re: Help with Inventor Files of Toughbox Mounting
Hi
I think that you can find here:
http://www.ifirobotics.com/kitbot.shtml
Documentation:
Frequently Asked Questions (FAQ) KitBot
Chassis Assembly Instructions (pdf - 0.7Mb)
Chassis Part Drawings (pdf - 0.4Mb)
KITBOT Transmission Mount 3D Cad Files (zip - 0.04Mb, 1-9-08)
KITBOT Transmission Mount 3D Drawing (jpeg - 0.22Mb, 1-10-08)
monitor Team 1946
Mohamed
Tamra-afr.net
Unread 12-01-2008, 14:30
Bochek's Avatar
AKA: Adam Bochek
Thank you, i did look there but overlooked the exact link... For reference the 2 pieces come in a STEP file by following the
KITBOT Transmission Mount 3D Cad Files (zip - 0.04Mb, 1-9-08) link
- Bochek
Unread 13-01-2008, 11:45
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
After mounting the Toughboxes onto the frame, I've noticed a few issues for our design. Compared to the Banebots long shaft to bearing blocks from last year, the Toughboxes have 1.658" output shaft. We only have room for one 15 tooth sprocket (0.75 " shaft side width) due to aligning the chain with either side of a 1" AndyMark Wheel.
The next best option for four wheel drive is to route a chain (or belt) from the connected wheel to the next wheel.
I have two questions.
What are simple ways to extend the output shaft ? (shaft couplers , using the 1/4-20 threads ... etc. )
Can the Toughbox operate effectively without a supporting bearing block on the standard output shaft ?
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 13-01-2008, 13:15
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Could you use one chain for both wheels? Or have one of the wheels offset a little so you could put another sprocket on the gearbox and have it go to the same side on the second wheel?
The toughbox will be fine without a supporting bearing as long as there is not a lot of load at the end of the shaft (i.e. cantilever wheel maunted directly on the output shaft, or sprocket on the end of the shaft and the chain wayy too tight). The Banebots needed a support bearing because the shaft was so long, and the nature of planetary gearboxes meant that it wasn't supported as well inside the gearbox.
Unread 14-01-2008, 09:23
lynca's Avatar
Andrew Lynch
It might be possible to fit two sprockets with the wheels slightly offset. I think our team will just settle for driving on traction wheel and having another separate chain from the traction wheel connecting to the omni wheel.
Thanks for your help !
Toughbox mounting bracket models Rob CAD 2 10-01-2008 11:34
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
Converting step files to inventor files GMAdan Inventor 4 01-01-2007 20:09
Help with Files tawnos484 Programming 4 20-01-2006 03:40
Can you use inventor files with 3DS Max? Ydnar Inventor 4 10-01-2002 14:23
