Go to Post Yes, the real world is like that. Let's operate on a higher plane. - Taylor [more]
Unread 12-01-2008, 14:39
cstringer cstringer is offline
None #2339
cstringer is an unknown quantity at this point
Help With Programming
I am a Programmer for Team 2339 and am a beginner at this whole programming thing. Any help with programming would be greatly apreciated. Any information needed to help I would be willing to supply to a certian exstent thank you.
Unread 12-01-2008, 15:37
JonathanLKS JonathanLKS is offline
Code::Blocks
FRC #0610 (The Coyotes)
JonathanLKS will become famous soon enough
Send a message via MSN to JonathanLKS
Re: Help With Programming
Well, first you should decide if your going to use EasyC or normal C/MPLab.
If your going to EasyC then making a post in the easyc forum would be a good place to start. If your doing normal C then you can either go on some online websites that help teach you C, like http://cplus.about.com/od/learningc/...rialprelim.htm but then you'd still need info on the specifics of programming for the robot. There are a bunch of papers on this that will help walk you through it, just hit CD-Media up at the top of the site and click search under Papers and just type like programming in there.
Of course if you have any specific problems or questions then just post them.
Team 610 [ Co-Leader | Head Programmer | Webmaster ]
We're attending: Greater Toronto Regional, San Diego Regional, Championship
Unread 12-01-2008, 23:14
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
The learning curve should be shorter with Easy/C, and they provide tutorial samples for everything you need to know to get started.
Unread 13-01-2008, 13:37
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
The learning curve is a bit less than MPLab, cause you only need to know what PWM is and such. However, I really don't like the blocks and stuff. If you really want to dive into highly flexible programming with MPLab, try using WPILib. It simplifies sensors so much, and clears out the ifi default clutter. Also consider, it is good enough that easyC is actually based off it. Either way, as you come up with problems, just keep posting, we're all here to help.
Help with programming Armando Programming 1 25-01-2007 18:41
Help with Programming double_check Programming 11 19-08-2005 00:15
Help With Programming! KWalsh Programming 5 24-02-2004 11:42
need help with programming magical hands Programming 1 11-02-2004 22:12
Need help with programming Kori E. Programming 7 24-02-2003 21:21
