Go to Post "Why do it the easy way when you can do it the hard way?:rolleyes:" - EricH [more]
  #181   Spotlight this post!
Unread 12-01-2008, 14:43
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Kevin Watson View Post
Replace "ifi_analog_channels" with "ADC_15ANA" and it should compile.
I just tried it here and you probably need to add this line at the top of the file: "#include <adc.h>". You can also just comment out the line and compile. On my to do list is replacement code for this function.
-Kevin
Kevin Watson
http://kevin.org
  #182   Spotlight this post!
Unread 12-01-2008, 14:49
NetElemental's Avatar
NetElemental NetElemental is offline
AKA: James E.
FRC #0418 (Purple Haze)
NetElemental is an unknown quantity at this point
Kevin,
Thanks - we already had #include <adc.h>, it seemed to come like that. Our mcc18 adc.h file actually did not have a definition for ADC_15ANA - it had 0-14 and 16. Assuming the intent is to set all the pins to analog, I changed "ifi_analog_channels" to "ADC_16ANA" if it helps.
In our file, we had
#define ADC_14ANA  0b11110001 // analog: AN0->13  digital: AN14->15
#define ADC_16ANA  0b11110000 // All analog
Weird, eh?
Thanks again,
James
  #183   Spotlight this post!
Unread 12-01-2008, 15:09
FRC #2429
Originally Posted by NetElemental View Post
Kevin,
In our file, we had
Weird, eh?
Thanks again,
James
Looks like their library documentation is messed-up. Use ADC_16ANA.
-Kevin
Kevin Watson
http://kevin.org
  #184   Spotlight this post!
Unread 12-01-2008, 15:13
Rindill Rindill is offline
FRC #1329 (VIPRS)
Rindill is an unknown quantity at this point
Using new code with Eclipse? How to make the correct makefile? Help?
  #185   Spotlight this post!
Unread 12-01-2008, 15:28
Ethan Reesor Ethan Reesor is offline
FRC #0418
Ethan Reesor is an unknown quantity at this point
Kevin,
I am currently working with the ADC and Gyro code for the mcc18 v3, using MPLAB IDE v8.0. I realized that I had v2.4 of the compiler, so I downloaded and ran the v3.1 updater. Now, when I compile, the linker tells me I have the wrong (out of date) COFF file format for the object files (*.o). Any ideas?
Here is the error:
Error - Coff file format for 'C:\Documents and Settings\Ethan\My Documents\Programming\FIRST\Code\ifi_frc_gyro\adc.o' is out of date.
-Ethan
  #186   Spotlight this post!
Unread 12-01-2008, 15:57
FRC #2429
Originally Posted by Ethan Reesor View Post
Kevin,
Here is the error:
-Ethan
Try using the "build all" option, which will recompile all source files before linking.
-Kevin
Kevin Watson
http://kevin.org
  #187   Spotlight this post!
Unread 12-01-2008, 16:07
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
I am planning on using the custom pwm.c/h code to generate the two pwm signals at 100Hz. I realized that unless I am also providing command and mointoring the system at 100Hz, it won't gain me anything (i.e. if I were to generate pwm commands in the 38Hz loop and update the commands at 100Hz, I don't think I'd gain anything). Hence I am also planning to update encoder-based pid loops at a rate of 100Hz. Not only this will give me a constant interval between updates, making my velocity estimates more reliable, it should make use of the faster update rate by generating commands at that rate.
Will doing something like that impact the performance of the the pwm functions? My PID loop code is not much more than a bunch of logical tests and integer multiplications. I am wondering if I should be okay if I call the PID code from within the Timer ISR that generates the pwm signal, or am I risking a significant drop in performance.
Thanks (and I hope my question is worded clearly enough - if not, please let me know, and I'll try to reword it)
  #188   Spotlight this post!
Unread 12-01-2008, 16:08
bronxbomber92 bronxbomber92 is offline
FRC #1551 (Grapes of Wrath)
bronxbomber92 is an unknown quantity at this point
This is related to the Beta code, but with default code compiled with MPLAB 8.00 and c18 2.40 I get a similar error to Etahn Reesor:
error - Coff file format for 'ifi_library.o' is out of date
error - Coud not find member 'ifi_library.o' in library file 'C:\filepathToProject\FRC_library_8722.lib'p
Any idea on how to fix this?
  #189   Spotlight this post!
Unread 12-01-2008, 18:31
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
It should be a matter of:
1) Adding encoder.c/.h to the project.
2) Putting #include "encoder.h" at the top of each source file where any encoder functions will be called.
3) Calling the encoder initialization function(s) from teleop.c/Initialization().
4) Enable the individual encoder channels at the top of encoder.h.
5) Assign the encoder phase b signals to digital inputs at the top of encoder.h.
6) Enable the interrupt(s) associated with each enabled encoder channel at the top of ifi_frc.h.
7) Make sure there are no conflicting ISRs enabled at the top of interrupts.h.
8) Compile and test.
-Kevin
Kevin,
I keep getting a link error
Error - could not find definition of symbol 'Int_6_ISR' in file 'C:\dev\ifi_frc_gyro\ifi_frc.o'.
even when I enabled interrupts 3-6 in ifi_frc.h
Thoughts?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
  #190   Spotlight this post!
Unread 12-01-2008, 21:09
FRC #2429
Originally Posted by Jon236 View Post
Kevin,
Thoughts?
The linker can't find the Int_6_ISR() function in your source files. You need to perform step #4 in the list and enable encoder #6. If this doesn't solve your problem, can you send me your code (I hope I haven't done something knuckle headed)?
-Kevin
Kevin Watson
http://kevin.org
  #191   Spotlight this post!
Unread 12-01-2008, 21:21
FRC #2429
Sounds like a fun project. I would not do my PID calculations in a ISR. Instead, I would set up a timer to fire off at 100Hz and then wait for the timer interrupt flag to go high and then do your PID calculations. The ideal place for this code is Teleop_Spin() and/or Autonomous_Spin(). Let me know if you have any problems.
-Kevin
Kevin Watson
http://kevin.org
  #192   Spotlight this post!
Unread 12-01-2008, 21:48
Jon236's Avatar
AKA: Jon Mittelman
-Kevin
All my problems went away when I downloaded you encoder_beta version.
Jon Mittelman
  #193   Spotlight this post!
Unread 13-01-2008, 00:13
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Originally Posted by billbo911 View Post
I have used this method in the past on my Vex bot. It works fairly well but is not perfect. For use in straight line driving, as in Hybrid mode, it should be sufficient. BTW, make sure you account for the dead-band associated with the Victor.
Yes, I am aware of that, but in this case the PWM is being driven with out any user input, should be ether 0 or 255, nothing in the middle.
  #194   Spotlight this post!
Unread 13-01-2008, 13:18
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I'm not sure I am following what the question is. If you have a PWM value that is going to be only one of two states, 0 or 255, then just test for one state. For example:
if (pwm03 > 127)
      accumulator ++;
else
     accumulator --;
I chose 127 just for simplicity.
Just as easily, you could test for the actual value.
if (pwm03 == 255)
      accumulator ++;
else
     accumulator --;
  #195   Spotlight this post!
Unread 13-01-2008, 15:12
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
It has been explained how to add encoders to the gyro code, how about the reverse?
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
