Go to Post everyone loves photoshops of Dave... - lukevanoort [more]
Unread 12-01-2008, 14:59
Semicolon's Avatar
Semicolon Semicolon is offline
Semicolon will become famous soon enough
A different kind of gear tooth question
Can the gear tooth sensor be used to detect something other than gear teeth? Our team is interested in just sticking some screws and nuts equally spaced around a wheel and line the gear tooth sensor up to detect the screws. We would probably need some iron based nuts and bolts, but it seems possible. Will that work? (note: We would use the sensor that came in the kit)
Stay with me here...
Everyone knows that Time = Money and Knowledge is power right? It is also known that Power = Work / Time. So then we substitue Power and time so Knowledge = Work / Money. Then we solve for money and get that Money = Work / Knowledge. So, As Knowledge approaches 0, the more money is made regardless of how much work is done.
Now we know that the less you know the more money you make, even with close to no work!
Unread 12-01-2008, 15:30
REVving up for a new season
FRC #2848 (All-sparks)
Re: A different kind of gear tooth question
the sensors in the kit will detect any ferris metal passing by, so in the case you described yes they will work. One thing to consider is the range of the sensor, as they need to be quite close in order to get a clear reading.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 12-01-2008, 16:08
Semicolon's Avatar
Thanks, this will help. BTW, I'm the programming guy, so I don't really know but... How do you know if something is ferrous iron or not. does it say? If it's magnetic then it's ferrous?
Unread 12-01-2008, 16:24
Durza16's Avatar
Durza16 Durza16 is offline
FRC #2062 (C.O.R.E.)
Team Role: Electrical
Durza16 is on a distinguished road
Ferrous is like steel or iron, a metal you can magnetize
any magnetic metal should work
dumb question: Where do we get the gear tooth sensors from? waialua359 Programming 6 30-01-2007 22:45
Question about Gear-tooth? Nicodemus Control System 4 21-01-2007 02:19
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
A different kind of support movement Carolyn Duncan Chit-Chat 5 16-09-2001 23:11
