Go to Post I'm tired of quoting the manual for today so all I will say is "Try again". - Vikesrock [more]
  #31   Spotlight this post!
Unread 12-01-2008, 18:23
captain1807 captain1807 is offline
AKA: Nicholas
FRC #1807 (Redbird Robotics)
captain1807 is an unknown quantity at this point
Re: BEST USE of the IR Remote!!!
Wow, I read this and it made sense.
I was toying with the idea of using them like toggle switches, but I never put 4 and 4 together.
Job well done guys, you are the beings of superior intellect.
2005 Montclair Mayhem Highest Qualifying Score (pre-rookie)
2005 Brunswick Eruption 4 (pre-rookie)
2006 NJ Regional Semi-Finalists
2006 NJ Regional Safety Captain of the Day
2006 NJ Regional Rookie All-Star Award
2006 FRC Championships in Atlanta- Curie Division
2006 Brunswick Eruption 5 Semi-Finalists
2007 NJ Regional Semi-Finalists
2007 NYC Regional Semi-Finalists
2007 NYC Regional Motorola Quality Award
2007 NYC Regional Safety Award
2007 Brunswick Eruption 6 Semi-Finalists
  #32   Spotlight this post!
Unread 12-01-2008, 19:02
flightofone flightofone is offline
AKA: John Clayton
FRC #2104 (Colonel Robotics)
flightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really niceflightofone is just really nice
Send a message via AIM to flightofone
We're planning on having the IR remote provide very similar driving functions to regular operator control. Our 4 buttons do:
1 - turn left 10-degrees
2 - turn right 10-degrees
3 - accelerate 2fps^2
4 - decelerate 2fps^2 (including going negative if already at zero)
Since the buttons can be repeatedly pressed as needed, this should provide decent driving functionality.
There's a fine line between fishing and just standing on the shore like an idiot. - Stephen Wright
________________________________________
2007 UTC Regional - Finalists (thanks 25 & 176)
  #33   Spotlight this post!
Unread 12-01-2008, 19:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Originally Posted by Alan Anderson View Post
It's obvious to me that the expected four signals/actions are something like this:
1) Knock off the ball in the leftmost spot
2) Knock off the ball in the center spot
3) Knock off the ball in the rightmost spot
4) Just go!
Can this also not be accomplished simply by setting your autonomous program at your operator controls after they randomly place the trackballs on the overpass? <G20> just says the players have to be in the alliance stations for the trackballs to be placed, NOT behind the lines. They can still make adjustments to auton before the match starts. If anyone sees any other rules which prohibit this action, I'd love for them to point them out.
I know not every team employs such autonomous program select functionality at their operator controls, but perhaps they should, given the added flexibility.
<G20>
TRACKBALL Locations - After all ROBOTS participating in the MATCH are in their starting positions and the TEAM members are in the ALLIANCE ZONE and/or ROBOCOACH STATIONS, four TRACKBALLS will be placed on the OVERPASS. On each side of the OVERPASS there are three TARGET LOCATIONS for TRACKBALLS. The field management system will randomly choose an initial starting location for the TRACKBALLS before the start of each MATCH. One red and one blue TRACKBALL will then be positioned
in the chosen TARGET LOCATIONS on each side of the OVERPASS. After this point in time no ROBOT may be moved or repositioned until the MATCH starts.
Now regarding the IR remote...
Not having really thought about it in too much detail, I'd consider the following four actions....
Start/Continue (Jump to Next Autonomous Step)
Stop/Pause (Signal End of Current Autonomous Step)
Tweak Steering Left some finite increment during motion
Tweak Steering Right some finite increment during motion
I do not anticipate much use of the remote in Teleop mode. Actions 1 and 2 would obviously not apply. Perhaps I could use Actions 3 and 4 to assist the pilot in making the left turn at the far end of the field should his/her vision be blocked.
  #34   Spotlight this post!
Unread 12-01-2008, 19:38
CyDrive's Avatar
CyDrive CyDrive is offline
FRC #1203 (pandemonium)
CyDrive is an unknown quantity at this point
The only other thing you need to worry about is also your starting position. Since you will have 1 of 3 spaces you will occupy the code will need to be changed for each space. So you would need to plan out who gets what space with your alliance members.
  #35   Spotlight this post!
Unread 13-01-2008, 10:55
fuherg1 fuherg1 is offline
FRC #2225
fuherg1 is an unknown quantity at this point
Our team's plan for hybrid and the IR is this. We are planning on making it so our robot will autonomously go for the middle part no matter what. But if there is no ball there we have a back up plan. We are using mecanum or omniwheels and will only need to press left or right. That way we wouldn't interupt the auto code and we dont need to waste a button on taking off the trackball. The other two buttons are now open to something else such as go around the corner and get the other ball or something like that. We don't want it to be just a small controller so we are using set out functions for it to do.
What are the best wheels to use on carpet? The GarbageMan Kit & Additional Hardware 10 09-04-2007 20:29
how do i tell to the edurc when the remote is on. Code\\Pilot Programming 4 28-01-2004 21:00
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
Best use of suction cups in Galieo? Spikey Championship Event 3 21-04-2003 20:36
