Go to Post The problem is though, as long as the teams are allowed to work on their robots on Thursday, they will, and they'll never learn to finish it before the event. - sanddrag [more]
Unread 12-01-2008, 21:40
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Weird IR Sensor Problem
Our team has a confusing problem. At first our IR sensor was hooked up to a prototype board and it worked well. It was receiving signals from the remote control and everything.
But then, in the course of hooking it up to our test bot, we reversed the pwms, mistakenly plugging the white signal wire into the ground on the digital in/out section.
Since then our board will train perfectly, but when we send a signal after training it, it just blinks an error light repeatedly until we power down.
We checked our 5 volt regulator and it is functioning just fine, and we never smelled any smoke. We also tried two different remotes which each worked when we had the IR Sensor hooked up to our original prototype board. When even rehooked the sensor up to its original prototype board, but it still doesn't work.
Does anyone have any ideas or advice on how to correct this problem???
Thanks in advance, Team 240
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Weird camera problem Shadow31 Programming 4 08-02-2007 18:46
Weird problem.. devicenull Programming 2 13-03-2005 12:07
Weird problem with if statements psquared Programming 7 27-01-2005 13:02
Line Tracing Sensor mix up problem 1166 Electrical 1 03-03-2004 10:14
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
