Go to Post "Professionalism at all times... even when you're playing an epic prank on your friends." - JVN [more]
Unread 12-01-2008, 21:54
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Re: How to conect solenoids to the circuit board. and how to program it...???
To connect the solinoids you will need a spike. The black which is ground (negative) connects to the circuit breaker panel where it says negative and the red connects to the same panel but to a 20 amp breaker not fuse. The m+ and m- on the spike is where you connect the solinoid. I believe that you take a black wire from one side of the solinoid and a red wire from the other side and put a connector to it, do the same for the other two. Also the programming for it is the default code which i believe uses relay outputs 2&3. Not sure on that one but this stuff should help you.
How to program ir sensor board?? RRA4LIFE2 Programming 1 11-01-2008 21:47
how to assemble the solenoids MNov Pneumatics 2 09-01-2008 00:02
How fast does the Solenoids turn on and off? Generalx5 Robotics Education and Curriculum 2 26-01-2007 01:09
Anyone know how fast the Solenoids on the MINI RC can turn on and off? Generalx5 Control System 1 06-01-2007 07:39
Does anyone have an idea on how to make a joystick program for an operating board? necroprime Programming 8 09-11-2002 19:04
